SOURCE: Won't turn ON
Time for new camera me think, if it is out of warranty.
These items are virtually unrepairable.
Money better spent on newer more uptodate version
SOURCE: Camera wont turn ON
hi lumix_user, these fuses are surface mount fuses and can not be changed by yourself, more damage will be done to the unit if you have no experience in the repairs department. take it from me i have seen what damage is done to units when they have been tampered with. please send to panasonic agents for repairs.
SOURCE: my camera is frozen.
your batteries may not be putting out enough voltage for your camera to run on. i suggest buying duracells.
SOURCE: camera will not turn on despite fully charged
This is generally not a good sign.
You can try removing or changing memory cards and seeing if that is the problem. They do (rarely) fail and lock things up.
You can also try a reset. Each camera will be different so have a look at your manual for details. You can try taking the batteries out for a day and then see if it starts.
Past that about all you can do is check for warranty and give tech support at Panasonic a call. They may have a different reset to try or will let you know if they have to fix it.
http://www2.panasonic.com/consumer-electronics/support/
SOURCE: After charging tz3 battery and put in camera it
Are you using the batteries recommended by the manufacturer? that is a very important fact, even though you can find other batteries that have the same specs, they make the cameras to where it will work best, and sometimes only, with the batteries recommended.
