How can I reinstall my acer orbi cam my daughter deleted it and now I cant get it back, can you please help and I have Windows Vista or can you suggest some better that will work with windows vista cause it was not working
There is a utility bar that you can install that lets you change the default application folder:
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
I recommend reinstalling the Orbicam driver and software. Here are the steps to do this:
1.
Move your mouse over the Empowering technology widget and click on the
eRecovery Manager icon or you may also press ALT and F10 on the
keyboard to start the program.
Please note: The first time you
access the eRecovery feature, you are prompted to create a password. If
you forget it then you will have to use the recovery discs to reformat
the system.
2. In the next window look at the bottom of the window and choose Restore.
3. Now choose Reinstall Applications/Drivers
4. Choose Install
5. Click on Windows Vista on the left side of the page
6. Choose applications and then choose CCD. It may also be under Camera in the drivers section.
7. On the right click the install link and follow the prompts.
8. The system may restart when installation is complete
Do not allow the system to shut down during this process. Plug in the AC adapter if necessary.
Good Luck!
SERIOUSLY THE SOLUTION TO THIS IS VERY SIMPLE ALL YOU NEED TO DO IS GO TO MY DOCUMENTS, PICTURE (CREATE A NEW FOLDER IN MYDOCUMNTS AND INSER ALL YOUR PICTURE IN YOU NEW FOLD *** DONOT NAME IT THE SAME NAME IT SOMETHING ELSE INSERT ALL YOU PICTURES IN YOU NEW FOLDER AND PRESS F5 TO REFRESH CLOSE MYDOCUMENTS AND CLICK ON YOUR ORBICAM PROGRAM TRUST ME IT SHOULD WORK
I accedentally delete my acer orbi cam extensa 4230.how can i reinstall it
I have tried the solution from #2 thr aoorebtuce in the name of Guest and it was the excellent news it worked, Iam proud of you.
Ali
Thanks a million
The solution if your acer orbicam improvvisely stopped to work (like
dead) is really simple. Download the updated driver file from the acer
ufficial website in the support division and reinstall it. After it the
orbicam will work again.
If you need the new drivers you can go also here:
www.eurocell-shop.it/Bison_CCD_5_0_0_10f.rar
Bye
Maurizio
To fix the problem about the webcam that improvvisely not is working more on your Acer 5100 and some other series proceed as I indicate:
create a new folder where to transfer the pictures contained in your images folder.
Then reinstall the the webcam driver.
For the future, leave the "images" folder empty or just put inside few pictures file (but for me would be better to leave it empty).
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
I agree with solution #14
It is the wiring on the camera itself. If I move the camera around I can get it to work. This, when all this time I tried deleting and downloading drivers, etc. My camera is logitec orbicam 1.3 mega and you can turn it to take pictures 180 opposite of the keyboard.
thanks guys
For those who have problem with their acer orbicam with windows vista try this: from "Start" cick "Run". Type "msconfig", it will bring u up "system configuration" window. Click on "Startup" tab. Search for "AcerOrbicamUVC" (or similar with that) and "CameraMonitor Application" . Uncheck both. Click OK. and then restart your windows. See if it works. :) good luck.
Go to acer-euro.com. they have orbicam drivers there.
my grand son did same. i had problem getting it started again untill friend told me to unistall windows photo gallery. i did that and downloaded orbicam drivers. it works ok now.
joel
Var YAHOO = {'Shortcuts' : {}};
if (typeof YAHOO == "undefined") {
var YAHOO = {};
YAHOO.Shortcuts = YAHOO.Shortcuts || {};
YAHOO.Shortcuts.hasSensitiveText = true;
YAHOO.Shortcuts.sensitivityType = ["illegal", "adult"];
YAHOO.Shortcuts.doUlt = false;
YAHOO.Shortcuts.location = "us";
YAHOO.Shortcuts.document_id = 0;
YAHOO.Shortcuts.document_type = "";
YAHOO.Shortcuts.document_title = "WEBCAM [Incident: 080315-000332]";
YAHOO.Shortcuts.document_publish_date = "";
YAHOO.Shortcuts.document_author = "[email protected]";
YAHOO.Shortcuts.document_url = "";
YAHOO.Shortcuts.document_tags = "";
YAHOO.Shortcuts.document_language = "english";
YAHOO.Shortcuts.annotationSet = {
"lw_1233370820_0": {
"text": "http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/[email protected]&p_next_page=myq_upd.php&p_iid=63509&p_created=1205616913",
"extended": 0,
"startchar": 602,
"endchar": 756,
"start": 602,
"end": 756,
"extendedFrom": "",
"predictedCategory": "",
"predictionProbability": "0",
"weight": 1,
"relScore": 0,
"type": ["shortcuts:/us/instance/identifier/hyperlink/http"],
"category": ["IDENTIFIER"],
"wikiId": "",
"relatedWikiIds": [],
"relatedEntities": [],
"showOnClick": [],
"context": "the following link or paste it into your web browser. http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/[email protected]&p_next_page=myq_upd.php&p_iid=63509&p_created=1205616913 Subject --------------------------------------------------------------- WEBCAM Discussion Thread --------------------------------------------------------------- Response (Online Agent-11) - 03/18/2008 01:17 PM",
"metaData": {
"linkHref": "http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/[email protected]&p_next_page=myq_upd.php&p_iid=63509&p_created=1205616913",
"linkProtocol": "http",
"linkTarget": "_blank",
"visible": "true"
"lw_1233370820_1": {
"text": "Windows Vista",
"extended": 0,
"startchar": 1797,
"endchar": 1809,
"start": 1797,
"end": 1809,
"extendedFrom": "",
"weight": 0.321004,
"relScore": 4.51285,
"type": ["shortcuts:/us/instance/other/product", "shortcuts:/us/tag/other/wiki"],
"category": ["THING", "WIKI"],
"wikiId": "Windows_Vista",
"relatedWikiIds": ["Apple_Inc.", "Dell", "Linux", "Mac_OS_X", "Microsoft", "Microsoft_Office", "Microsoft_Outlook", "NVIDIA", "Windows_2000", "Windows_XP"],
"relatedEntities": ["mac os x", "macbook", "microsoft", "microsoft office", "outlook 2007", "windows server 2008", "windows vista ultimate", "windows xp", "windows xp operating system", "windows xp professional", ],
"showOnClick": [],
"context": "Now choose Reinstall Applications/Drivers 4. Choose Install 5. Click on Windows Vista on the left side of the page 6. Choose Applications",
"metaData": [ {
"visible": "true"},
"visible": "true"}
"lw_1233370820_2": {
"text": "Product Level",
"extended": 0,
"startchar": 2550,
"endchar": 2562,
"start": 2550,
"end": 2562,
"extendedFrom": "",
"weight": 0.279854,
"relScore": 3.32819,
"type": ["shortcuts:/concept"],
"category": ["CONCEPT"],
"wikiId": "",
"showOnClick": [],
"context": "with voice audio- unable to speak . Robbin Question Reference #080315-000332 --------------------------------------------------------------- Product Level 1: Notebook Product Level 2: Aspire Product Level 3: Aspire",
"metaData": {
"visible": "false"
"lw_1233370820_3": {
"text": "Operating System: Windows Vista",
"extended": 1,
"startchar": 2896,
"endchar": 2926,
"start": 2896,
"end": 2926,
"extendedFrom": "Windows Vista",
"weight": 0.349861,
"relScore": 5.06248,
"type": ["shortcuts:/us/instance/other/product"],
"category": ["THING"],
"showOnClick": [],
"context": "03/15/2008 04:35 PM Last Updated: 03/18/2008 01:17 PM Status: Solved Operating System: Windows Vista Serial Number: BWHJ4X2GBBWRG3HHKGBMWYX42 Date Purchased: 01/01/2008 [---001:002052:62282",
"metaData": {
"visible": "false"
YAHOO.Shortcuts.headerID = "4a374a4ae8f7309496e5ba0c93b2af6d";
DIV P {
MARGIN: 0px
I was having the same problem, so Acer Tech. send me this message on how to restore my web cam. Good Luck
1. Move your mouse
over the Empowering technology widget and click on the eRecovery Manager icon or
you may also press ALT and F10 on the keyboard to start the program. Please
note: The first time you access the eRecovery feature, you are prompted to
create a password. If you forget it then you will have to use the recovery discs
to reformat the system.
4. Choose Install
6. Choose Applications and then choose CCD. It may
Respectfully,
Acer
America
Online Technical Support
Customer (Robbin Hobdy) - 03/15/2008
04:35 PM
I cannot locate my webcam ICON-and I am having a problem with
Robbin
Lol you just need to eset the computer...take it to best buy or somewhere and they will make your comp just a shell and then reload the factory software...this will delete any problems and files
1 of the best Solution.i own a acer laptop, with same problem, cannot locate webcam,cannot find camera hardware,disconnected,
well this is it most probably best Solution.
with my pc Technician Friend, we remove the cover of the Hardware, and we Discovered the Wire inside the Unit is loose,
and besides we have also a Custumer 3 of theme have same problem of mine, and also in same solution, we open the Laptops we fix all the Wires connected from the Hardware,( Camera only ). After that We made it. the camera is Working.
Four of Us same Problem, With same Solution for Acer Orbicam
my Problem is solved
Hey I have a acer aspire 5100 and my camera stopped working also. So I contacted acer about the problem. They gave me some instructions to fix it and it worked!!! First we will create the new folder where the pictures will be moved to: 1. Click on the Start button. 2. Click on Computer 3. Double-click on the C drive 4. Double-click on Users 5. Double-click on your user name 6. Double-click on Desktop. 7. Once you are in the Desktop, right-click on a blank white area (not on an icon) then select Create > New Folder. 8. Call the folder “Picture Backup” or any other significant name. (Do not close the windows since we will need it later) in step 11 Now we will move the pictures from the old folder to the new one: 9. Click on the START button then click on Pictures 10. Click on one picture and then go to Edit > Select All. This will highlight all the files in this folder. 11. Right-click on one of the selected files then select Cut 12. Go back to the folder we created in step 7 and 13. Right-click and paste the contents we Cut from the Pictures folder. Now, restart your computer and try the OrbiCam application again. This should allow your OrbiCam application to work again.
Restor system to early time if only icon is deleted,,if program is uninstalled,,try to restore operating system to an early date.if it does not work,,try to restore windows using recovery cd comming with laptop.
SOURCE: Acer orbi cam
Start - Programs - look for Acer Empowering technology Acer E-recovery - choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say extracting) - once extracted - click Install - click Vista on the left - click Drivers - click Camera or CCD - on the right side of the screen, click a phrase that has something like "Install now", follow on screen instructions.
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that folder to another folder and restart Orbicam program.
unfortunately there could be the possibility that your acer cam is not compatible with vista.. vista is a tricky os right now so it is particular on devices and compatability issues--i was an early adoptor and it isn't fun.. i would check out logitech cams, they seem to work well but look for the vista compatible.. you may want to visit your acer website and see if there are any update or downloads for current users that now have vista.. hope this helps..
d
install your drivers brunella then do a windows update ignor when pop comes up says cant do it with the continue button hit continue on the driver install and do windows update
windows vista doesnt like the older equipment for some reason it doesnt work well with some new hardware just to let you know vista is still in its infancy stage getting better as its source and updates go along
http://www.acer.com.au/acer/service.do;jsessionid=295090CBF4856EE81846F87C26D0E077.public_a_14c?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3112&sp=page15e&ctx2.c2att1=92&miu10ekcond13.attN2B2F2EEF=3112&CountryISOCtxParam=AU&ctx1.att21k=1&CRC=3559666452
u can chk out driver and software from here
I have the same cam installed but i can't find a way to configure it. I did in once with skype but i'm looking for an individual program to adjust quality, color, exposure, etc..
Any suggestions? :(
My acer orbicam is not working. everytime i click the incon would give me a prompt saying that that a problem caused the program to stop working and windows will notify me when a solution is available. I just purchased this laptop and for some a reason the orbicam just stopped working.
I have a message appear on my screen telling me that
ACER ORBI CAM APPLICATION CAM HAS STOPPED WORKING.
I have already spoken with a member of Acer technical team who said he would send me an email to try to resolve the problem. Ten days later this has yet to arrive.
I have also emailed Acer, approximately one week ago with the same problem. Yes, I am still waiting to receive a reply!
Cam someone PLEASE tell me how to resolve my problem as soon as possible.
Thank you.
Audrey
[email protected]
my acer orbicam application opens up but my camera for some reason does not... so i can see the application window but no images. and there is also no light on the camera to show its on. i just upgraded my vista home premium to ultimate. this is a new notebook.is it a hardware problem?.. i tried to download drivers but the application said my drivers were up to date
webcam quit working
My orbi cam does not work as well.
Acer OrbiCam Problem on Vista, light comes on but no image. Driver says this unit is working properly.
acer orbicam won't work
My acer orbi cam won't allow me to open the program, the camera works but i can't see what i am viewing
i have deleted acer orbi cam by accident how do i get it back
cam broken
I would like to know how to activate the orbi cam because i have not mastered activating it yet and would like too. I've tried looking on the website for instructions but none were found.
My acer orbi cam stopped working on my aspire 5100 at first I was gettign messages saying something to the extent that it stopped working.Then i tried to go to the acer site to reinstall it but that did nto work and now the orbicam program seems to have disappeared. Is there anythng I can do to get it workign again?
My Acer orbi cam has stopping. the green light was going on but now it does nothing. Please Help!!
The camera totaly malfunction,furthermore the "acer orbi cam" icin cannot be selected
camera
I was having some problems with my Orbicam and I was told if I uninstall it it will start to work. But now I don't know how to re-install it.
i have the same problem as xtraordinary, after upgrading it stopped working, application loads but no picture or light.. i have removed all photos from my pics folder but still doesnt work and drivers up to date.. help
Orbi cam does not work, It tells me, that It is not working propperly, I was trying to download driver for Vista, but It does not help.
when i click on acer orbicam program to open it it shows " Acer orbiCam Application has stopped working" "a problem cause he program stop woking correctly window will close programand notify youif a solution is available."
please help
there is just a gray screen. i cant get it to work..what do i need to download?i already tryed vista ....
yes i have the same that the other person mentioned
i have the same problem as most people do. my acer orbicam will not work. when i click on the icon, it says acer orbicam application has stopped working. HELP!
my camera just flat out stopped working!!!
The solution if your acer orbicam improvvisely stopped to work (like dead) is really simple. Download the updated driver file from the acer ufficial website in the support division and reinstall it. After it the orbicam will work again.
Bye
Maurizio
no one
I deleted it from my computer by accident.. and I want to re- install it... how do I do that?
Program will not open at all. Says problem is an interanal error and windows searches for solution and then closes program because no solution exists.
the acer cam wont work and says that the program is searchin to solve the problem.
ya i have same problem,first orbicam application stop working and now cam is also not working....
MY CAM STOPED WORKING ALSO, NEW 17" ACER AND USED IT 1 TIME, TRIED TO DOWNLOAD DRIBERS ECT,AND DIDNT HELP, ACER STILL HASENT REPLIED AND NOW I UNISTALLED IT AND IM TRYING TO FIGURE A WAY TO REINSTALL FORM START, FRESH, ON ACER ASPIRE 9300
my computer was wiped of all progerams and i dont know how to get the orbicam to work
i have had my acer laptop for about 1 year now and when i re-boot my computer the orbi cam program doesnt download onto my computer and i dont know how to get it back?
i had the same problem an was excited to get help , I did all the picture moving an so on ... but now a new error comes up, some fatal...not a jpeg if anyone can help id really appericiate it .
when i go to my documents and open this program it says that it isnt working properly and it says that it will inform me when it finds a solutin but it never does what do i do?
acer orbi cam ha smesso di fonzionare
MINE IS ACER 9300 AND THE CAM STOPPED WORKING, JUST SAYS IT CRASHED AND WONT WORK, SO HOW DO I FIX THAT_??
my camera just stopped working one day. i really dont know what is wrong with it. can you give me things to try.??
acer orbi cam hasn't worked since i've gotten the computer.
acer orbi cam .. not a jpeg file starts with 0-47;0-49
Orbi cam has never worked, went into acer management & tried to solve it that way but now it has disappeared alltogether, dont know if its deleted. How do i get it back?
stopped working wont run the camera
orbi cam seems to be uninstalled can not find programme or driver to reinstall
My orbicam works with Skype, but when I want to take a foto it said that the orbicam is not installed. How can't it be uninstalled, while it works????
my camera just isnt working when i click on the icon. Im not sure if a file got erased.
"ACER ORBI CAMERA APPLICATION HAS STOPPED WORKING," EVEN BEFORE STARTING UP. PLEASE ELP.
I have the same problem
i click icon, but orbicam will not activate
It just quit working
It just stopped working.
I CAN.T FIND MY ORBICAM PROGRAM
MY ORBICAM NO TRABAJA
I tried to get my Acer Orbi cam to work but It got Deleted by Someone?
i uninstalled acer orbi cam how do i reinstall it
the webcam
not working
I sent my laptop to get fixed. When I got it back Acer Orbi Cam was deleted. How can I get it back?
A friend cleaned my computer off and he wiped my computer out and i need my web cam back
its been deleted
Orbicam doesn't work
My web camera acer orbi cam, ina a notebook aspire 5100 stopped working. how can I fix it ?
cam not working
when i click on my acer orbicam is says this rogram is no longer working.
can i have a driver installer
deleted drivers
My one just stopped working I need to reinstall it.
the webcam doesn t work apears a problem stop working and shotdown
acer orbi cam stopped working and i accidently removed it from acer aspire 5610z
orbi-cam not working
i deleted my acer orbi how can i get it back please help!!!
i deleted the program because i was told to delete it and then restart the notebook nd when i did that it woyuld reinstall by its self and it didnt help!!!
When i click on my acer orbicam icon, my light on the cam won't light up, and it will be a grey screen and won't receive my the image. So basically it's not working.
i have done nothing till now.
My acer orbi cam got deleted and it will not work now
same problem: after the updates from vista cam stopped. the system is not able to detect the cam on the usb.
cam wont come on
Somehow my orbi cam software never got installed or is missing. I have been trying everything to get it to work but can't can you help me.
acer orbi cam application has stopped working.
I HAVE ALLREADY INSTALLED THE ACER ORBI CAM (AS IT SAYS ON THE DEVICE MANAGER) BUT THERE IS NO SHORTCUT OF THIS APPLICATION ANYWHERE IN MY COMPUTER AND SO I CANT USE ORBI CAM
reinstall acer orbi cam.
I reformated my laptop and now my acer orbicam and my notebook speakers are not funtioning
acer orbicam has stoped working
my girlfriend deleted it and i need help to reinstall it
i have the same problem. i tried to use an updated driver, and everything went to hell. every time i start bisoncam, witch apparently is now the bisoncam, its just a gray image. there is nothing else there! if i try to use webcam on my msn messenger, its just gray. i NEED my webcam to work, its VITAL! gurr....
hi..how do i reinstall orbicam?
REINSTALLED DRIVER, AND STILL CANNOT GET CAMERA ON. CAN;T FIND.
a few days ago my sister deleted acer orbi cam program and ı don't install it now what can ı do? my computer is aspire 5100
I had to CLEAN the hard drive and reinstate vista. When this was done, the orbicam simply would not work. Appreciate any help thanks David I have an ACER TravelMate 4235WLMi
My Acer orbi cam is not working, when i click the orbi cam, the programm opens but not the cam.. the orbi cam is already installed in my laptop. now what should i do to get the cam on.. kindly suggest me...Parvez..
Orbicam isn't working don't know what to try.
my orbi cam do not work i tried to update it but it still want work please help me.
acer apire 5050/3050 series.
my orbicam not working i also deleted it and i dont know how to install it back on..i need help!
acer orbicam has been accidentally deleted what can i do to get it back?
i was accidentally deleted my orbicam and i cant used it now... what i should do to re install it, i have a window vista and an ASPIRE 5610-2328 acer computer. please help me
i made a mistake and uninstalled my program that operates orbi cam my cam is still attached to the laptop 5100 acer 17inch screen. how do i get the program back?
my acer orbi cam is not working:
i am getting an error message : "Not a JPEG file: Starts with 0x7f 0x56"
can any one help. I followed the steps sent by acer customer support,
still getting the same error
thanks
the cam does not work
When i bought my acer notebook, tha acer cam was working, but the quality was poor. after a while it stop working properly. i installed new software and it worked for a few second, however, ti stoped working. Now my computer is telling me " a web camera is not found or is not working properly". I cant get it to work
it said dthat a program had caused it not to work.
help me i delete my web cam n now it's not working and i have windows vista!
i have a 5100 acer laptop and i put in a digital camera program and my orbicam stopped working. so i tried to reinstall it with add and remove programs and instead it removed it. how do i get it back please.
obicam does not work. aspire 5100 series laptop, pcsays it is workng properly no sofware or driver to be found inside
can't locate web cam
I have the same problem.But, I have UBUNTU in my computer.How can I install it?
Acer orbi cam has stopped working
I have an acer
I have acer aspire 5050 driver problem orbicam pls help..
same
I have upgraded the driver for the orbicam , now I cannot find the file anywhere.
when I check if the device is there..it is. I guess that somehow I deleted it..how to I get it back.
my web cam have stop working
web cam not working
activate orbicam on aspire 5610
i know its frustrating i tried to delete it then re install it but nothings working please help
Quit Working
acer 5100....i hate this gosh damz bull shattz i hate ACER rawrrrrrr stuoid **** no work so i have it unistalled and tryed intsaling it and boom nothing wack!!
I've had the acer 5100 for over a year and i used the orbicam when i first got the laptop. soon after, the web cam stopped working for no reason
ORBI CAM DOESNT GO
acer orbi cam doesnt work
Someone dleted the software for my web cam.
well i left my lap top on my bed and i came back and acer orbi cam was gone
cam not working
i uninstalled my acer orbicam programme when trying to update it?
i want to re installthe obicam
my acer model is aspire 5570
my acer camera wont start, everytime i try to start it up says it need to look for updates or something!
cam not work
my daughter has deleted the acer orbicam off the
laptop & i need to get it bak , i need to
reinstall the camera .
Someone put a passcode in and i can't use it now. Can I uninstall it and reinstall it without the disc?
i have deleted my acer webcam icon would like to know how to put it back i have an acer aspire 9300 pc notebook can anyone help me please
I click acer Orbicam and get a message that says it has stopped working. I check online for a solution. It says to go online and get an update.
acer aspire 5102 wlmi orbicam
I've updated my Windows Vista, and now I can't find obicam program to install it back.
My obi cam is no longer working all of the sudden how can i get it back
I tsays it isn't functioning
My acer orbi cam is built in my laptop. It always used to work until one day it didnt and it came up saying it isnt working and there isnt a souloution. I was really upset because i wont be able to use it ever again now. Please help
i acidentally deleted the orbi cam and driver software and i can't figure out to get it back and i don't have the disk that came with it cause i bougt the laptop from a guy one of my friends know and when it searches the internet for the software i says it can't do it what do i do?
acer extensa 4230 i accedentally delete it.
The orbi cam stopped working so i deleted it by uninstalling it, then tried to reinstall but dont know where to get it to reinstall??
orbi cam works nomore
My cam doesn't work in Messenger but its does work in normal desktop but i think i have removed it and now even in the desktop i could not even open it.
my cam don t work cause i think my friend deleted it cause it keeps saying that it cant find the problem but i dont know what the problem is but if it is deleted can i download it for free cause i cant afford it if i have to pay! can you please help thanks.
my cam wont work, no disc
I never used the web cam - but now 3 years after the purchase, I signed up på Skype and the cam just woun't take any pictures only show the image
ACER Aspire 9413ZWSMI lab-top
orbi cam won't work anymore
my orbicam keeps displaying an error message that the camera is not working.
I DELETED MY ACER ORBI CAM BY FOLLOWING INSTRUCTIONS FROM WINDOWS BUT NOW I CANT GET IT BACK.I DELETED BECAUSE I WAS TRYING TO FIX IT.
