Dryers Logo
Posted on Apr 29, 2009
Dryer tries to start - then stops and beeps PLEASE HELP
Fisher and paykel ed56 starts - does half to one turn - then stops and starts beeping. Beeping does not stop until turned off at powerpoint. Please help!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4754
Points
6
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
1helpful
Fisher and paykel ed56 prob year 2000 starts - does half turn - stops and starts beeping. Light dry & medium dry light come on. Beeping does not stop until turned off at powerpoint.
When was the last time it was serviced? Sounds like a faulty temperature sensor. Get it serviced, good clean out and sensor checked. Replace sensor if faulty.
Fisher and Paykel ED56 dryer won't run.
Glad to got it taken care of. Next time be a little more careful, I usually recommend using a leaf blower.
1helpful
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 • Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
2helpful
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
9helpful
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2009 • Dryers
21helpful
2answers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Top Fisher and Paykel Dryers Experts
Virgil Watts
john h
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
