If you cannot get volume control on you tube or any other apps your 30 pin connector( where you plug your charging cord in) needs to be cleaned. Take a tooth brush with some rubbing alcohol and clean it. May have to repeat a few times but that'll solve your problem
When you're on the youtube video, there should be a slider at the bottom to change volume level, or you can use the volume buttons located on the upper left side of the iPad, or you can double click your home button very quickly, then swipe the task bar twice to the right, which will also bring up a volume control.
