Question about Ricoh Aficio CL2000N Laser Printer
Error code sc486 on ricoh Pro c651 - Ricoh Aficio CL2000N Laser Printer
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Ricoh CL2000 SC486
Realizar a troca do BK Solenoid.
Ele está localizado dentro do driver onde estão as engrenagens, ao lado esquerdo da impressora atrás da placa BICU
Posted on Jul 18, 2008
Anonymous
  • 22 Answers
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
Posted on May 30, 2009
gggg
  • 904 Answers
SOURCE: printer jams when printing and I ricoh cl2000n
sc486 is a solenoid error with the black drum unit. The most likely culprits are a bad engine board and a bad drive unit, neither one of which is cheap unfortunately. You should contact your local service technician and have them take a look at the printer to see which component is causing your problem.
Posted on Dec 19, 2010
Sc 558 error code on Ricoh Pro C720
That is an oil supply pump error for the fuser. It probably needs to be replaced.
Jan 29, 2015 | Ricoh Office Equipment & Supplies
SC558 is a Oil supply motor error The machine detects a motor rotation error for 5 seconds after the oil
supply motor has rotated for 5 seconds. ?? Oil supply motor defective
?? Oil supply unit defective
1. Replace the oil supply motor.
2. Replace the oil supply unit.
Why does error sc486 power off/on occur when printing
Something inside printer is blocked. There is a magnetic clutch that sometimes could be a reason. Check that Waste Toner bottle is not full because in that case many bad things can happened.
I can tell you this for sure:
it's time to replace the printer with new one!!!
Maybe you will be able to buy cheep SPC410, SPC420. They are perfect
May 21, 2014 | Ricoh Aficio CL2000N Laser Printer
Sc-486 on the Ricoh Aficio CL3000 printer
sc486 is a problem with either the engine control board or the drive unit, or the connection between them. One or the other will probably have to be replaced, depending on exactly what's causing the problem.
Mar 22, 2011 | Ricoh Aficio CL3000 Laser Printer
Code sc486
BK Solenoid Error : The BK solenoid cannot drive the black PCU
Engine board or Drive unit is probably broken
Jan 22, 2011 | Ricoh Aficio CL2000N Laser Printer
Printer jams when printing and I ricoh cl2000n error code sc486
Dec 10, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000 SC486
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000 SC486
May 21, 2008 | Ricoh Aficio CL2000N Laser Printer
Richo cl3500n error code sc486
Reinstall the driver again.
Regards,
Ashok
Feb 13, 2008 | Computers & Internet
Ricoh Aficio CL2000N Laser Printer Logo
839 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
