i cant get you what code you need. either you need unlock code to unlock your phone from your network or you need security code to unlock your phone from security password. if you need security code you need to reset your phone. you can try resetting your phone through codes. its the safe way to
reset your phone. if you want the unlock code for your phone you can get it here. Theunlockarena.com
The default security code for Nokia is 12345 If the default security code doesn’t work, I need the IMEI (International Mobile Equipment Identity) type *#06# on your phone to get it, you can also find it beneath the battery. I will then calculate the Master Code for your phone.
Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code.
The default security code for Nokia is 12345 IMEI: 353235015522555 Master code: 2564610140 Close all applications on your phone. With your phone switched ON, remove the battery. Then remove the SIM card. Replace the battery without the SIM card and switch your phone on. Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code. This is the code needed to reset the Security code, nothing else, and it’s for your phone only. If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
For mathyn IMEI 010972008260174 Mastercode 5255056051 For mc hot IMEI 359838011209921 Mastercode 1600246040 For Guest IMEI Type *#06# to get it. Mastercode ?????????? For emanuelgaby IMEI 354528013559796 Mastercode 7367245612
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
Phone Security Code: This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a "new" sim if the phone security code is entered.
This is the code needed to reset the Security code, nothing else, and it's for your phone only. You type in the security codes (any) until the phone request the Master code, when it does, leave your phone still, don't use it for 15 minutes, then type in the Master code.
