Gateway mx6453 thought I heard a snap and the comptuer went dead.
It sounds like you have a fault with the power port on the mainboard or
power board (quite a few gateways have a separate power board) , the
battery won't charge if this damaged or loose which would explain the
dead battery. The smell is probably caused by sparking on the loose
power port. I wouldn't try to power it on anymore as you may damage it
further. it is possible that the area around the power port is burntout
therefore rendering the powerboard or mainboard useless but they are
replaceable at a cost. If the laptop is still under warranty then you
will need to take it back to where you brought it.
You will need to take it to an engineer to have it assessed unless you are able to make the repair yourself. Good luck hope this helps.
