SOURCE: cant find my wireless card in device manager in acer travel mate 2300
In some Acer models, there is a software switch in Start/All
Programs/Acer Launch Manager. If this is missing, you need to reinstall
since even with the WiFi hard switch activated, this application is required. This is so especially if a
new/clean/OEM install of the OS has been done on the laptop.
In some models, there is a hard switch either at the front or at the side to activate the internal wifi (and bluetooth). Still in other, there is button on the leading edge of the computer which also serves as an indicator lamp,
Some models also have WiFI enable/disable in the BIOS/CMOS setup.
Still others have a button along with the Easy-launch strip (top) together with the those for email , bluetooth , Acer Arcade & others.
As shown above, depending on the specific model/region version of your laptop, the WifI activation can be varied.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: bluetooth prolem on acer aspire 5720
welcome to FIXYA
Set up a Bluetooth enabled deviceTo set up a Bluetooth enabled device, you need to do three things:
This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
To do this, you must:
To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer’s website.
To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
To install a Bluetooth enabled device
Click Add, and then follow the instructions.
i hope this helps you out have a good day :)
SOURCE: wireless connection problems
Yes!! I finally have a solution. On my wireless Acer Aspire 5720z. (From vista to XP) What I do? Ok. I download the vista-7.1.0.90-whql from the .ck page. With this one the Acer recognice the wireless but have problem with the installed driver. Then I download the xp32-7.6.0.239-whql, go to My Computer rigth click to properties, hardware tap, Click devive manager, on network adapter right click, Update driver and update with the xp32-7.6.0.239. That is all. Sorry for my bad English. Puerto Rico lo hace mejor!!!! Maury
Si finalmente encontre como resolver el problema de wireless the mi maquina Acer Aspire 5720Z. (de Vista a XP) que fue lo que hice. Fuy a la paguina que algunos hablan .ck y baje el programa comprimido vista-7.1.0.90-whql con este ella pudo ver el wireless pero tenia problemas con el driver entonces baje el xp32-7.6.0.239 le di update al driver y resuelto el problema. Gracias a todos los que alludaron de alguna manera o otra!!!
SOURCE: Not able to connect to internet, using wireless router (SKy),
One of the things that I have seen that might fix this problem is running a program called winsock fix. What this does it reset/rebuild your network config on your laptop. You will need to download this program from the other computer and then take it to the laptop via thumbdrive/cd. Here is the link. Hope it helps.
http://www.snapfiles.com/get/winsockxpfix.html
SOURCE: ACER 5720 WIRELESS CONNECTION PROBLEMS
I have an Acer 5420 which had a persistent disconnection problem after startup, with either the wireless or LAN connection. It appears that the Microsoft network application would startup and make the connection, but seconds later the Acer Enet Management application would start, and its first act would be to disconnect from the Internet. Since the Microsoft network application provides every feature that I want, I choose to disable the Acer Enet Management.
