Volunm inop,works manualy as long as holding button down,as soon as released starts progresivley droping to zero. volunm display stays on screen of tv and can not actsess menu. remote inop as well. good picture also.
open the hood and find the speedometer cables according to your auto's manual, check to see if they are securely connected to the ports on back of speedometer. if this doesn't work. find the function button front of speedometer press and hold while starting engine, will enter function mode,press button repeatedly untill you come to auto. press and hold button untill "-" appears then release button , unit will show on screen,wait untill a line of zero's appear on screen then drive around untill you go over one mile, stop the car and press the function button again,the speedometer is now recalibrated this usually fixes many errors
Hello First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps. * Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released". ** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released. *** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
I came across your post, pauline_h716, and I'd like to provide some assistance! If you could let me know what kind of TV you have (for example, Sony, Vizio, etc.), I can give you the codes to get the remote programmed. In the meantime, follow these steps and let me know if you have any questions:
Remote: Basic Remote (Television Only)
Turn the Television On.
Press and hold the TV Power button for three seconds until the LED flashes.
Press and release the TV Power button.
Press and release the Up or Down Arrow on the remote until the television
turns off.
After the television turns off, press and release the OK button.
Test functionality with the TV.
Return to Step 2 if the remote is not able to turn the TV On/Off, change the
volume and mute the television.
with the computer off. start by having it plugged in. now press and hold down the 0 (zero) key. while holding it down press and release the power button.. as soon as you see it power up release the 0 (zero) key. this will restore to out of box state. it will take aprox and hour. You wont have to do anything just let it run the restore..
If you are trying to use a Dish Network remote control, then you are probably out of luck. Most Dish remotes do not have remote codes for TV/DVD or TV/VCR combos. There are just too many codes out there to put into one remote control. I'm sure they tried to walk you through a code search (hold the TV button down, etc.), so if it didn't show up then, then you are probably stuck with using two remotes or adjusting manually.
If they didn't try a code search, then try this:
Turn the TV on manually. Then, press and hold the clear TV button at the top until all the buttons at the top turn red, then release. Press and release the TV power button (the smaller red power button), and press the channel up button. Repeatedly press and release the channel up button about once a second until the TV turns off by itself, then press and release the # button at the bottom right hand corner of the remote, and the TV button will flash 3 times, confirming that it took the code. Press and release the clear SAT button at the top left, and then you should be good to go.
If the TV never turns off during the code search, and the TV button at the top of the remote flashes a bunch of times everytime you press channel up, then there are no more remote codes. The remote does not have the code for your TV.
