I have a sylvania model src22 13 b serial No. V32361565 . I need the code to reprogram a new remote control. The new remote is a RCA . Thank you for your help.
0038,0031. Try these codes. If
you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many
popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic
/ Flip card, can be selected by the drop-down list, by the top left
of the display window, will make surf easy
SOURCE: remote controle codes
Try this website: http://www.thompsontv.com/rcarc.html
Hope these ones work, thanks
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
SOURCE: Reprogram RCA Remote to Sony Television
1 Turn on the component you want to program.
2 Press and hold both the TV/DVD/ect button and the power button untill the light comes on and stays on
3 Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
4 Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on.You may have to do this up to 10 times until it searches through the bank of ten codes sent.
5 Press and hold the stop button until the light goes off. This saves the code.
SOURCE: Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
