I have a 7"Android 4.0 tablet PC. I entered a password and when I tried to use the password the table would not accept it I have tried several times so I can not get into my tablet. What can I do?
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
It's hard to tell you exactly how to do this without knowing which tablet you have. I'm guessing that it is an Android tablet and some of them (if you linked them with a Google account) will let you unlock them remotely through Google. This will have to be done by entering in the wrong password several times and then it will prompt you to try your Google account.
If that doesn't work you will most likely have to perform a hard reset on the tablet. Understand that doing so will wipe any personal files and reset it to the same state it was when you pulled it out of the box for the first time. I would recommend connecting your tablet to your computer and downloading any pictures or music you have on it first.
To reset the to reset the tablet some tablets have a small pin hole located on them that you can insert a paperclip into to reset the tablet. Some tablets will let you enter a development mode by holding down the volume-up key and the power key for several seconds. This will let you reset the device to factory settings.
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here... http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Good luck.
its brand new and you forgot everything already if you did the google mail password assist then open that if dont know that or didnt do it can try provider for assistance and most lockouts are either 1hr or 24hr
An authentication error is an incorrect password being entered. Make sure you are typing it in correctly. Remember, passwords are case sensitive. Please check with your internet provider if you are unsure of your Wi-Fi password.
try and hard rest the tablet go to youtube type how to hard rest a your make and model of your tablet and a few videos should come up watch them and it will show you how hard reset your tablet
Hello Jachin, if you still have this problem. Try doing a "hard reset" - Turn off tablet - Hold down the power and volume "down" key together - when red text appears select "yes" by holding down power key for 10 secs.
Reformatting shall commence
Please note that this process works on most android tablets.
