Logitech Harmony 700 LCD Remote Control Logo
Jared Cohen Posted on Nov 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code to make a harmony 700 work with a samsung tv
Level 3:
Top Expert:
  • Logitech Master 76,851 Answers
  • Posted on Nov 03, 2013
Logitech Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005687
Points
237762
0297,0291,0295. Try these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy.
1 Related Answer
Anonymous
  • 7191 Answers
  • Posted on May 13, 2010
SOURCE: Is there a free manual for Logitech Harmony TV remote
You can download the user manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
tip
Harmony 700 Manual Download
Download Logitech Harmony 700 Remote Control Manual
Have you misplaced your Logitech Harmony 700 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 700 Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 • Televison & Video
tip
I hope that helps.
2answers
I have a Samsung smart tv. We use a harmony remote to control it. We are unable to shut it off, adjust volume, change stations
There is a code for every tv that you will have to load into the remote. Ask Radio Shack person how to get your code onto your remote.
Samsung UN46D6300 TV not in Logitec Harmony 700 remote database. Need IR code/s to enable controls (especially TV input source selection). Learning mode was only partially successful for power, volume...
When i went into the Harmony software, your TV did come up. If these codes aren't working try a different model Samsung (like UN46D6000). All new Samsungs use the same code set. If this still doesn't help, go to "Devices"->"Settings"->"Adjust Inputs"->"Method 3". Follow the directions from there. Something else that may help is Samsung calls it the "Source" button, Logitech calls it "Input x".
1helpful
I need to know how to program my logitech harmony 520 remote control with samsung tv
You should just be able to plug the remote into your computer with the USB cable supplied, go to the Harmony website listed with your product packaging, and Harmony will walk you through (very user friendly interface) a process which sets up your personal account, downloads the necessary setup software into your remote, and automatically programs your remote to whatever device you identify. With what you've said, all you need in addition to the Samsung brand name is the model number. The rest is done by Harmony including code installations.
I have the Harmony 600, linked to a tv and vcr and the setup/programming process was as uncomplicated as anything I've seen.
2answers
How do we charge the harmony 700 remote
Your Harmony 700 should have come with a USB cable and AV adaptor to charge the remote.
Samsung PN58b530 tv and harmony 550. When setup have all devices set except when the tv turns on it stays on one hdmi setup then jumps to another that was not programmed.
Samsung TV's have Anynet automatic input switching. This severely conflicts with the Harmony Remote as they both do the same jobs; Switch inputs automatically. We would like for you to disable this feature on your Samsung TV using your original remote, so the Harmony Remote will work properly.
Disable Samsung Anynet+
1. Press your Tools Button.
2. Scroll down to Anynet and press your Select Button.
3. Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4. Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote.
I have a Harmony 700 remote and a device VCR/DVD functions were activated to this remote.I have however deactivated this device from my TV settings.So I want to delete every functions from the...
if you want to delete all functions and then update with your new settings, please see below
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Harmony 659 won't learn samsung LN-52A850S1F remote
Samsung has recently acknowledged an issue with 8 series LCD TVs (e.g. LN52A860). When the TV is first turned on, it outputs strong IR interference which can render the Harmony unable to control your devices for several minutes. After the TV is warmed up, the interference dissipates and the Harmony will work correctly again.
To determine if your Samsung television is causing the issue:
1. Start an Activity that uses your Samsung TV
Confirm the Harmony is not controlling your devices
2. Completely cover the screen of your television with a blanket or dark colored sheet
3. Try changing the channel. If the device now responds, the television is interfering with your devices. Please contact Samsung for support
It is possible that by disabling certain features on your TV can also resolve the issue. Features that may cause interference with your remote include:
1. DNR/Active Control
2. Power Saving Mode
To disable either of these features, please consult the user manual for your TV.
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
