Yes you could be hearing the freon running thru the sealed system. it might be normal, and also you could be hearing the unit going thru a defrost cycle. either way its not likely a problem. just keep an eye out for food getting warm. ice cream, breads and juices need to be at zero degrees to be solid. meats can still be rock hard at 20 degrees. if your unit is not cooling then you will find those items getting warm first. make sure the door is closing properly before you call for service!
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
SOURCE: Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
SOURCE: GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
SOURCE: Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
SOURCE: maytag plus refrigetor not cooling model msd2756geb
after removing all of the freezer racks and shelf pull the 4 1/4 inch screws out at the bottom back panel of the freezer. pull the 2 panels off and slide them out strait down to the floor of the freezer. if your freezer coils are full of snow and ice then the fan cant pull any cold air up into the refrigerator.your problem is probably th defrost adaptive timer. if the heater ohms out at around 20 to 30 ohms it is ok. next ohm the 2 white wires at the plug this is checking the thermostat it shoud ohm out at aproximately 240 k ohms if those 2 things check out the problem is the adaptive defrost timer it is in the ceiling behind the temperature controls on yhe right side.
Update I have pulled the back panel and found that the noise is coming from the evaporator and it is not a vibration noise.
