SOURCE: hp scanjet 8250
Hi
I've always found that you need to power off and disconnect the USB cable. Also, if the computer is left on most of the time and you haven't used the scanner for a while, just restart.
Phil
London SW13
SOURCE: Document feeder
You would face the taxt or images face up then you would scan it by using the program it came with if it did or any othere program the can scan documents and imagees on you computer. Make shure all conecsions are conect property and the software is installed.
SOURCE: need operating manual hp scanjet 8250
Go to this link. It's a PDF file, so you'll need Adobe Reader installed.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bps05869/bps05869.pdf
I found it by going to the Support & Drivers section of HP's Web site (www.hp.com), clicking the "Download Drivers and Software" option, entering "Scanjet 8250", clicking the Go button, and then clicking on the "Manuals" link in the left-hand column about 3/4 of the way down the page.
SOURCE: cancel double sided copying
You must select 'simplex' option for single side scanning. 'Duplex' refers to front & back scanning.
S. Mohan
SOURCE: compariable print driver for HP scanjet 8250
if you go to the HP website you should be able to download the latest driver form there.
