I can get my computer to recognize my flip cam using the usbs in the back of my computer but not the front. the first time i put the drive into the front usbs, an error of some sort and then wouldn't see it at all when i plugged it in again. now it will only recognize and upload videos when i plug it into the usbs in the back of the computer. please help!
Plug in your flip. Click start, control panel, adminitstrative tools, computer management, storage, disk management. right click on flipvideo. Choose 'change drive letter and path' Pick a drive letter, any letter that is not currently being used on your comp (try U). Tada it should read your flip
Finally I solved it!!!!
Situation:
My Computer (MAC And PC) wasn't recognizing the FLIP ULTRA HD, because it has a corrupted file, but couldn't format because there was no communication between camera and computer
Solution:
1. Charge your batteries until get the FULLY CHARGED icon (Green Battery)
2. then remove the batteries without unplugging the USB
3. Voila...computer recognize the USB
4. Format the Camcorder with the Following tutorial:
http://www6.nohold.net/CiscoFlip/ukp.aspx?vw=1&docid=763c871b45fc4b20b5a671b24c909
20e_Reformatting_and_Reinstalling_FlipShare_
on_a_Flip_Camcorder.xml&pid=4&respid=0&sni
d=2&dispid=0&cpage=search
5. Install software in camera...
6. CONTINUE VIDEO CLIPPING!
SOURCE: My FlipShare software cannot recognize my Flip MinoHD
Have the same problem with my Flip Ultra HD on my MacPro! Who can solve the problem??
SOURCE: The flip mino hd usb won't plug into most of my
My flip mino hd USB also will not plug into my MacBook Pro. I've tried it on 3 different machines and it will only fit into one port, and not at all easy into that port. When I look at the USB connector on the device, there appears to be slight raised plastic ridged on the outside ends of the connector.
Yes thumb drives do work in the front ports and so does my ipod. I am using Windows 2007.
Ugh me too! I dont know why this is happening...but you could try emailing the flip video people @ [email protected]
This product is really bad. The LED light in front is on indicating its on, but the screen is black and I can't turn it off. I can't connect to my computer either.
whenever i plug my flip in, my comp doesn't recognize it!
Do others things such as a thumb drive work on the front ports? Which OS are you using?
