My ENT doctor said no more ear buds, no more ear phone so I Amazon purchase another GOGEAR Ariaz because they have an external speaker, or so I thought.
I tried all to get the speaker ARIAZ 16 gig to work. Nothing. Speaker does not work. The instruction manual that comes right on my 16 gig GoGear Ariaz is for titled GoGear AZURE!
AZURE! Where did that come from? The Azure manual does not show a speaker. Go figure. I do not think my Ariaz-Azure has a speaker. It does have Bluetooth that works for me OK with a Philips external Blue Tooth Speaker. No ENT correct external speaker on the player itself? Or am I wrong.
The tiny, tiny micro writing label on my "GOGEAR Ariaz" is a label for "SA5AZU16KF/37. Even though the Logo on the case of the GoGear is imprinted ARIAZ!
If I am wrong and my Philips Azure???-Ariaz has a speaker I would be pleased to know how to make the speaker work.
PS, I do own a GoGear ARIAZ 8G, and it does have a speaker that works for me.
SOURCE: I need a users manual
User manual for the SA2VBExx player is available with next link:
http://download.p4c.philips.com/files/s/sa2vbe04p_02/sa2vbe04p_02_dfu_eng.pdf
SOURCE: Creating Playlists for GoGear Aria 8gb player
If you want to make a new playlist for your 8 gig GoGear Aria, all you have to do is highlight the songs you want to add, then right click the mouse and choose create playlist. Name the new playlist then cut and paste it into "Playlist" in the music choices and there you go. No WMP needed.
SOURCE: Philips 8gb Gogear SA3085/02 -"DRM License not available"appears
In your Windows media Player go into tools and select options. Select rip music and untick copy protect music. The music you have in WMP wont work. you will have to put them in again after you made the changes. Hope this helps
SOURCE: It says on the phillips
yes your correct there are different types /size of mp4 s here is a video on Philips site that explains what sizes format are acceptable usually the player comes with a disc that has a free tool to convert videos to proper sizes hope this helps and please vote
SOURCE: I have Phillips GoGear Vibe 8GB SA2VBE08K It is
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
Here is a page which shows you how to transfer music over to your new Phillips Media Player. Windows Media Player sync is specific to Windows products. Do NOT use this to transfer music to your Phillips media player. Use the software supplied by the manufacturer.
If this solves your problem, please come back and rate our solution. Thank you.
Testimonial: "Great! That worked. Thanks so much!"
