Question about Quinny BUZZ 3 Capri Stroller
How to fit the brake release on a quinny buzz
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: fitting quinny footmuff
hey it took me a while to figure it out, at the top of the padded shoulder straps at the back if you feel with your fingers you will find a popper fastening you have to pull it so that it comes away then you should be able to find that the harness is attatched by a loop, take that off and then with the harness unattatched you can thread the slits of the footmuff through and then reattatch it all including the padded shoulder straps, i took mine apart today because my daughter has outgrown the comfort cushion so i took it off after realising there was a bigger seat unit undernath it i bet not alot of people know you can do this, anyhow, by adding the footmuff it makes it alot more padded and cosyier hope that helps!
Posted on Apr 07, 2008
Anonymous
SOURCE: Toddler to big for quinny seat
http://www.babycare.nl/quinny-buzz-seat-p-1437.html
Posted on Apr 29, 2009
Babycare_nl
Erwin de Raad
  • 21 Answers
SOURCE: front wheel conversion
Hi Nathan,
Please have a look here:
Buzz 4 front wheel
and alternatively the
Buzz All Terrain Wheels
International shipping is available.
Hope this helps.
With kind regards,
Babycare.nl
Erwin de Raad
Posted on Jun 24, 2009
SOURCE: does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
Posted on Sep 06, 2009
Marie Lowe
  • 223 Answers
SOURCE: how do i fit the footmuff on my quinny buzz pram?
Hi, to fit the footmuff, you need to undo the straps which can be done right at the top shoulder bit. Once this done you then thread the harness through the side holes on each side of the footmuff, then through the top hole & re-attatch harness to pushchair. All that is left to do it push the **** strap though the bottom of the footmuff. Hope this is of help to you. Regards Marie
Posted on Aug 29, 2010
Quinny brake release pedal not working
Hi
There is a page attached for adjusting Quinny Buzz brakes. Try this and see whether it resolves the issue.
If it doesn't resolve the issue, the next step is inspection of the unit. If it's under 2 years old and you're in the UK, please contact your retailer with proof of purchase for them to arrange inspection under warranty terms and conditions.
If it's over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
If you're not in the UK please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab for your enquiry to be sent to the customer care team for your country. 3_23_2013_9_05_40_pm.jpg
Mar 17, 2013 | Quinny Buzz Three Wheel Stroller
Quinny buzz brakes arent working
Hi
The Quinny Buzz brakes can be adjusted (and should be periodically as part of the ongoing maintenance of the product to ensure good performance)
The brakes may require periodic adjustment. To do this, use two 8mm spanners to unlock the lock nut from the long barrel nut. Adjust the brake cable and retighten the lock nut. Test the brakes to ensure a positive engagement and disengagement after adjustment.
Sep 19, 2012 | Quinny BUZZ 3 Capri Stroller
Which adaptor will fit a quinny buzz pram and a maxi cosi cabriofix?
You can purchase Quinny Buzz adaptors via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) RRP is 10GBP a pair plus 3.99GBP p+p if ordered direct. These adaptors will fit a Maxi Cosi CabrioFix, a Maxi Cosi Pebble, or a Quinny Folding Carrycot to the Quinny Buzz chassis.
Nov 24, 2011 | Quinny Baby Gear
Would a bumper bar for a Quinny Buzz fit a 2009 Speedi Legend
The Quinny Buzz bumper bar is only for the Quinny Buzz and will not fit a Quinny Speedi.
Sep 12, 2011 | Quinny Buzz Jogger
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Jan 11, 2011 | Quinny BUZZ 3 Capri Stroller
We have the quinny buzz, 2007 model and wondered i...
The Lascal BuggyBoard will fit on the Quinny Buzz in both the Pram and pushchair mode. However, it's a bit of a tight fit for your toddler. We had the same issue.
May 20, 2010 | Quinny Buzz Jogger
Can a buzz seat fit speedi frame
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Mar 06, 2010 | Quinny Buzz Three Wheel Stroller
My brakes on my quinny buzz will not work .Can't get pedals to press down ??
take wheels off give them all a really good clean as the breaks are pin fit breaks and are sensitive to dust and muck which can be picked up being out and about x
Nov 09, 2009 | Quinny Buzz Three Wheel Stroller
Quinny Buzz brake will not release!
Contact Quinny directly via their parent website www.dorel.co.uk/contact-us
The frame has a 2 year warranty so they should be able to help
Aug 12, 2009 | Quinny BUZZ 3 Capri Stroller
What is the difference between the 2009 vs 2008 quinny buzz 3??
Buzz 3 2009 improvements
  • Front wheel: rotates better due to ball bearings
  • Rear wheel: fitted with ball bearings; easy to mount
  • Suspension; now made of rubber instead of steel, offers more comfort.
  • Push bar: new fabric
  • Bumper bar: new fabric
  • Central sliding hing: offers more stability
  • Brake: easy-to-operate brake pedal, audible click when locked
General note: All screw connections are coated with environmentally friendly powder glue to guarantee a consistent, reliable and stable connection
Aug 10, 2009 | Quinny BUZZ 3 Capri Stroller
Quinny BUZZ 3 Capri Stroller Logo
42 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
