Not being an electronics expert i would have to say this is bad, and not your power supply but your entire motherboard. The only times i have seen this with these problems the fix was a new motherboard. The hot glue is fluid from the capacitors when they overheated and blew up. But somebody else out there might now more then me about electronics so maybe they will have a different answer. sorry.
SOURCE: Compaq Presario SR1030NX fails to start
Sounds like the power supply or motherboard is biting the dust. U may consider power off, open case and clean out the dirt, check U'r connections and if the power supply smells, replace it.
Else replace the pc. When the power supply dies, it usually stresses the motherboard out and it dies later, sooner.
SOURCE: Hard drive fan stop working computer stop
Disconnect the pc, remove the side panel. Use a bright flash light or directional light, carefully remove the cooling fan from the mother board. If there is signifiant dust built up on the fins and inside the fan, I would buy a new fan to replace it. But before buying the fan...have a good, close look at the mother board. If you can see what looks like heat damage then take the pc in to the shop.
SOURCE: I'm having touble with a compaq presario s4020wm.
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
