The machine thinks its flooded. Simply remove the drain cover filter and tilt the machine forward until water stops running out. Turn on machine and problem solved
Have you tried to clean the filter recently ? If you have , water may have seeped into the machine, tip it forward and the water should drain out , if it does the same error you have something leaking inside the machine.
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Have you tryed to reset all the dials to zero disconnect power for a couple of minutes and check hose pipe not bend anyware then riconnect power set a wash and start.hope this helps also check pressure of water at inlet.
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it ie a crack in the plastic allowing water to escape
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
