While removing side by side freezer door i broke the 1/4" plastic water line in the door. could you give instructions on how to replace this water line. thanks
You need to remove the door from the refrigerator, then remove from the door the plastic frame carefuly, its snaping, and attach the new (1/4") line to the end of existing line then pull up the existing line softhly until the new one appears, check before all this if the line is broken at then of door or in the middle and if leak is below the refrigerator check from the solenoid to the door.
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
both doors use a part called cam&riser on the lower hinge,its broke and needs to be replaced. The part number is WR02X11743 it could be ordered by a google search by simply googling the part number. to replace it remove upper hinge(hinge cover if has one) lift off affected door and replace cam&riser, if on freezer door the water line to the dispenser must be disconnected and the wiring needs to be unplugged, to unplug squuze release tab and pull plug apart, to disconnect water line push in center collor of connector union and pull line out
Hope this helps if it helps please give me 4 thumbs up
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in door is frozen , GE has a heater kit , pt # WR49X10173 , for this particular problem . It comes , with installation instructions .
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
