SOURCE: CHARMGLOW PATIO HEATER WON'T STAY ON
Probably a venting problem! Can be very difficult to diagnose and repair'
SOURCE: Charmglow pilot won't light at all.
I would say that the lines still need to be perged. This some times takes a few times to get it going . If it has set for a long time or have run low on gas.it only takes a little air pocket to stop the works. Ask the man back. $125.00 is a lot of doe for no go. DFD
SOURCE: pilot lites but burner doesn't
If your pilot light is ignighting, it means only that you are getting gas to the heater, if it doesn't stay burning after holding the button down for 30-60 seconds, it could be 1 of 2 things or even both. The second one and the easiest is that you oxygen sensor click off you flame due to you not having enuff good clean clear air coming into the machine, maybe a blockage or something...check it out, maybe us some canned air to clean it out good. The 1st. and most likely
reason is your thermocoupler has gone and died on you and you need to go to the store and get one just like the one you have or at least one as long as the one you have ...hey! good luck! -Brady3
"[email protected]"t
