Allen & heath xone 42 fader problem channel 1 (phono) keeps working, even if the fader is down at 00
SOURCE: I have an allen and
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
SOURCE: I would like to buy
Cases are being sold on Ebay, new, from several sources, and if you can't find one specifically listed for your unit, contact the sellers as they custom build them. That is a big unit... expect to pay around $150 to $200 for an ATA type case for it.
Here is an example for a Heath/Allen 420. http://cgi.ebay.com/ATA-CASE-ALLEN-HEATH-ZED-420-ZED-420-ZED420-MIXER-/400127078772?pt=LH_DefaultDomain_0&hash=item5d296eb174
I have bought from them before myself and there are others on Ebay so shop around... You can contact the companies and ask for a specific one and DO compare the size to your unit that they specify as all the companies do not accept returns...
