After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST:
ERROR
2010:
Warning: Your internal hard disk drive (HDD) may not function correctly
on this system. Ensure that your HDD is supported on this system and
that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
Solution
There are three possible workarounds to eliminate the error:
Additional information
This error is purposely generated to alert the user to potential
problems with diagnostic or copy tools. There are known issues with
several of these listed below.
Note: This update requires a floppy disk drive.
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior.
The
hard drives shipped in the affected systems will not display the
message because they already have firmware that recognizes this new
Serial ATA bridge chip. However, a similar drive from an earlier
ThinkPad system or an OEM drive might cause the error message to be
displayed. Customers may also notice the POST error message after
applying a ThinkPad BIOS update if a drive without the firmware update
is installed in the system. Some early systems were shipped with a
system BIOS version that did not provide this POST error message.
Updated BIOS has been released to provide this informative POST error
message to users.
how i fix the problem for 2010 on my laptop r52 ibm
When do you get the messgae, and how is it displayed?
