RCA F27450 27" TV Logo
Posted on Apr 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn my TV on, it clicks on and off 5 times then stays off
When I turn my GE TV on, it clicks on and off 5 times then stays off. I can not get my TV to stay on. Can you help me please? Model # 32GT740 Serial # D245C2125 Chassis # CTC203CA12
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 318 Answers
  • Posted on Apr 30, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
318
Questions
0
Helped
86234
Points
527
First check a switch contacts, that switch has two make contacts in side it. if the switch is okay, then check a power supply dry joints on it.
or a dry joint on the line out put transistor, or a line transformer legs.
How do I do an automatic code search on a ge unigersal remote control model 24993 - v4
1 manually turn on device(TV, VCR,ect. Be sure batteries are good in remote.
2 press and hold the CODE SEARCH button until the red indicator stays on,then release Code search button.
3 press and release mode button (TV, VCR, ect) the red indicator blinks,then stays lit.
4 press channel up( up to 300 times) until device changes channel. The red indicator blinks,then stays lit.
5 Press the Mute button release to lock in code
Tips if you go pass the code use channeldown when channel change hit the mute button and release it to install code.
20helpful
2answers
Lost programing instructions and codes
1. turn on device
2. press setup (underneath on/off) till red light stays on the take finger off the button
3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once
4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press
5. press and release enter to install code
3-Digits Universal Remote Codes
4-Digits Universal Remote Codes
GE #24912 Universal Remote Instructions
GE Universal Remote Instructions
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
How do i program my ge remote to my sanyo tv
1. turn on device
2helpful
Lost my manual - need tv codes - ge universal remote - tv to program is a rca xl100 remote
Hi! The code of a GE Universal remote for a RCA TV are 0031, 0004, 0048, 0054, 0094, 0100, 0102, 0107, 0129, 0191, 0005, 0009, 0000, 0162, 0163, 0342, 0003 ,0015, 0022, 0096, 0113, 0125, 0179, 0187, 0188. In case none of these works for your TV you can try these steps for you to program your remote conrol.
1. Manually turn on the TV.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired TV button. The red indicator blinks off once.
4. Press the ON-OFF button repeatedly (up to 300 times) until the TV to be controlled turns off. The red indicator blinks off with each button press.
5. Press and release ENTER to install the code.
1helpful
I need a code for a ge universal remote to my orion tv
HOW TO PROGRAM GE JASRM24912 Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
12helpful
2answers
RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
Turns off by itselt, now won't turn on
Hi
did you see the standby light? in this case you said 5 to 45min. before the unit turn back on, this needs to check the oscillation circuit or the starting capacitor in the Hot area...
Thanks...
2answers
Ge universal remote
5helpful
6answers
RC24912 - D
1 manually turn on the device (tv, vcr. etc) to be controlled
2.Press and hold the setup button until red indicator stays on, then release the Setup button.
3. press and quickly release the desired device button (tv vcr etc). the red indicator blinks off once
4. Enter the following codes then press the channel up button and if anything happens the light will go off.
Jenson TV codes 0004, 0009, 0133
If you can't get any of these to work then you will have to do the exhausting manual version.
CODE SEARCH FOR THE RM24912
4. press the channel-up button repeatedly (up to 300 times) until the device to be controlled changes. The red indicator blinks off with each button press.
5. press and release the mute button to install the code. Then the light will go off.
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
