Dont have owners manual. I hit factory reset and now I can here the movie just cant see it, I have it set up on colorstream. Also how do you get the close caption off. Thanks Keith
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Be sure in the menu setting that the audio analog/digital setting is correct for the blu ray setting. All try the factory reset as stated in owners manual
WPS means Wi-Fi Protected Setup it is asking for the Password for that network If you do not know the Password and are the owner then try a reset then be sure to set it up so that it is not accessible to the Public. To do a reset look for a small hole on the back of the unit and depress the reset button located within this hole for 10 seconds or more. If you are the owner and you did not set a password then is more than likely set by an outside user which you more than likely did not know about. But do not worry this is preventable by setting up the security after the reset. See owners manual for how to go about setting up security.
You may reset the player to factory defaults via the Preferences menu. This step should eliminate the existing password. Additional details can be found in the owner's manual.
you pressed the color system format button/settings.on the remote press the P/N which means pal/secam and ntsc.press it several times or until you get a steady picture.when its black and white then you can press the set-up or menu button to correct your settings.
Hiya, when you go to your router homepage, normally an address like 192.168.2.1 for most belkins, there will be a security tab, if you look at the wep settings it should give you what the wep key is, if not you can generate a new one and put it into your pc's and ps3,
Your password however if not changed from original will be blank just hit the submit button,
Also there should be a reset button in the casing of the router, this will reset it to factory where password will be blank so hit the submit button, hope this helps
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up].
2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
anyone have any ideas?
how do I do that I cant see anything on tv
1st ....................WHAT MAKE AND MODEL
