SOURCE: reset all orginials in DP
HI, donot worry is not big problem, first of all open the Dp(Document processor which means the document feeder) and check if there is any paper or anything stucking there, if you sure there is nothing, you have to go into maintenance mode of the machine and reset this message, donot worry i will show you how step by step:
first of all press status buttom from the operation panel, then hit 1087 twice it will take you to maintenance mode, then hit 906 and hit start, u will see word on the screen highlight it and then press start, it will take seconds and will tell you to put the machine on and off, so then you have to press the main power buttom off and then on, hope this will fix your problem, let me know if you face any other problem. thanks for joining fixya.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
SOURCE: I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
SOURCE: I HAVE A PHOTOCOPIER MACHINE KYOCERA KM 1635, DOES
According to the manual you can not scan with it. Sorry. Also here is the manual if you need it.
http://www.kyoceramita.eu/dlc/eu/documentation/usermanual/km-1635-2035-og-uk.-downloadcenteritem-Single-File.downloadcenteritem.tmp/KM-1635-2035-OG-UK.pdf
Good luck and please rate
Testimonial: "it was100% p"
