Question about Toshiba TEC B-572 Printer
Ribbon error /paper jam
Will not print / goes to ribbon error then states papper jam
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Probaly due to a wrong mounting of the labels and the transfer films
Posted on Sep 10, 2014
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Posted on Mar 21, 2009
My 510s is having issues with printing. The print ribbon is sticking to the paper, thus tearing the ribbon and causing a paper jam.
Remove any slack in the ribbon by turning the ribbon-tightening knob, or reinstall the ribbon cartridge...
First Turn the printer off, open the printer cover and remove the jammed paper if paper is jammed..
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Unknown Hiti P510s 6 Dye Sub Roll-type...
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
It says tacke away papper from huvud fack in swedish. its no papper wher they come if it prints att it shuld. whats the mater it maks mi nervus . cant print enything its stuck one this error message!?...
You have not cleared the entire media path, or you didnot open the door specified by the message to check for jams in this area.Please clear media from the entire path, open the door indicated by theoperator panel message, clear the jam, and close the door and the printer resumesprinting. For further assistance, please contact LexmarkTechnical Support.
Jun 16, 2011 | Lexmark C510 Laser Printer
Incomming fax same page printing contenusly and wasting paper
put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Feb 13, 2011 | Ricoh 3310Le Fax Machine, FAX3310Le...
My printer pulls the papper half way to print and then it sound if it was printing but the papper doesn't move i already restarted it unistall the program n reinstall and it still does the same thing
check paper path with test print
right click printer icon go to properties click test print
can you see and remove the jam in paper path Check rollers for slick coating on them they are soft rubber and can get glazed so to speak
remove all parts that you can including paper drawer recheck the paper slot adjustments
sounds simple fix just recheck the paper path for jam or glazed rollers
1 Question ??no error message ?
Jun 11, 2010 | Lexmark Office Equipment & Supplies
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
PRINTER JAM
look for small, small pice off papper in the printer where pappers pass tru
Sep 29, 2008 | Dell 1720dn Laser Printer
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
Toshiba TEC B-572 Printer Logo
233 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
STEVE
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
