Televison & Video Logo
Jose Lampert Posted on Nov 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hdmi does not work
Apparently burned
David Low
Level 3:
  • LG Master 458 Answers
  • Posted on Nov 11, 2013
David Low
LG Master
Level 3:
Answers
458
Questions
Helped
138914
Points
1304
Surprised to hear that the HDMI input connector is burnt, however have you tried another HDMI port? If none of the HDMI inputs are working then a software updat could fix it or the HDMI switching IC maybe at fault. If you get a picture from the spare HDMI ports then the faulty HDMI socket can be replaced by an engineer.
2answers
I have a Sony DVD VRD-MC6, is there a way to connect my iphone to this model? I do not have a DVD Burner on my computer. Can I buy something to connect to my computer to make a DVD of my iphone videos
Dear Sir,
As I know Sony DVD VRD-MC6 do not have HDMI input so it not possible to record your video direct from iphone . but I phone has support to hdmi output thru iphone to hdmi cable and your Sony DVD VRD-MC6 has AV input so you need a one another device which call hdmi to AV converter it will work but your video quality will compromise.
If you want to record video form computer you need external dvd writer and one dvd burning software
After that you just copy your iphone videos thru usb cable and burn thru dvd burning software
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
2answers
When i plug in anything to the HDMI ports on my TV i can get audio but no video. This was working find until the other day, is there a way to reset this?
best bet is to buy a new HDMI cable and if it works in your tv then you know it was the original that was faulty but if not then the problem will be the TVs HDMI slot... if so then try testing the HDMI cable in the multiple HDMI slots on your tv (also trying both ends in each device) and if its still not working then try the TV setting but i dont think there is a setting but its worth a try :)
Toshiba 55g310u - HDMI Ports are not working( No Signal)
Had the same issue for one of my Toshiba ports. Had to call for service. Apparently, the circuit board is fragile and after plugging in cables many times, the HDMI outlet separates from the board. Trust you have warranty coverage....
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
2helpful
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
2answers
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
50 INCH HITACHI ULTRAVISION HAS COLOR DIFFERENCE ON EDGE OF SCREEN
Hey, I found this on a blogsite about lcd rear projections....looks like our tv's screens have been burned by the "pillers" that surround the tv when switching from 4:3 to 16:9 or fullscreen... read below, I hope it helps !
cheers!
Vern
Rear projection crt's,the first generation widescreen tv's were notorious for that.Lcd and plasma can have the same problem,but it takes much longer and is not as harsh.Dlp's use tiny mirrors,so it isn't a problem with them.Lcd and plasma tv's should be ok unless you watch them with blck bars on them all the time.
We have lcd monitors at work,and i've seen them after a year with bad burn in.They also run 24 hrs a day 7 days a week with the same display.
GKar posted 2006 Oct 10 15:31 TooLFooL : i have 51" sony rear-projection and those freakin' grey bars burned themselves right into the screen...
I read that to avoid the burning you had to limit your 4:3 viewing time to 15% of total time viewed. (applied to my TV but apparently yours and others as well...great! now they tell you :-x , this applies unless 4:3 aspect was changed to stretched or zoomed...yuck :-x )
This really sucks as a Star Trek/Lexx/Farscape fan as they are mostly 4:3, fortunately the upconvert player/hdmi combo sends a 1080i 16:9 signal to my TV so the effects are drastically reduced by nearly filling the TV without the grey bars or burn in problem without stretch or zoom modes being used. yay! :wink: (default grey bars set to black automatically, apparently grey isn't needed due to screen area covered is sufficient for burn in not to be a problem.)
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
