SOURCE: LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation.
to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hose, it may be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
