Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message
How to correct
CHECK INK
U041
An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause printer malfunction.
U051 / U052
U053 / U059
The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the
printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur.
U075 / U076
The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position.
U140
An ink cartridge not supported by the printer is installed.
U161 / U162
A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing
the ink cartridge. However, the remaining ink amount cannot be detected
properly, so the function to detect the remaining ink amount does not
operate.
READ/WRITE MODE
Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON.
NO PHOTOS ON CARD
Some images in the memory card may not be in a
supported format. images listed below cannot be printed directly from a
memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep
INCOMPATIBLE CAMERA
The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2.
Set the camera in PictBridge print mode before it is connected to the
machine. This is required before printing for some cameras that support
PictBridge.
Please refer to the camera instructions for more
information about procedures required before and after connection to
the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer.
WASTE INK NEAR FULL
The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing
can be done until the waste ink absorber becomes full. If the waste ink
absorber becomes full, please contact your local Service Center for
replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc.
CHECK PRINTER
Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center.
HEAD ALIGNMENT ERROR
Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment.
LOAD PAPER
If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center.
PAPER JAMMED
Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Installed new cartridge and am certain there is no paper feed problem. However, ther error message persists
Same problem
I replaced the ink cartridge but it says to check cartridge.
