Sony KDF-E60A20 60 in. LCD HDTV Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen goes dark, sound goes quiet...
Every 30 seconds, screen goes, dark, sound goes quiet for 20 seconds, then comes back on. Can a bad lamp cuase picture and sound problems? TV is 3 years old tomorrow.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
515
Points
5
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
Anonymous
Level 3:
President:
  • Master 814 Answers
  • Posted on May 18, 2009
Anonymous
Master
Level 3:
President:
Answers
814
Questions
0
Helped
447546
Points
1474
This may be a problem with the power supply board losing power and coming back on intermittently. This also could be a problem with the control board having the same problem. This unit should check thoroughly by a service technician for bad components due to overheating and aging You can go on to the Sony website at www.sony.com. Go to the support section and put in the model number of your television and check the frequently asked question and troubleshooting sections to see if some has had this problem and had the solution posted.You can call Sony television service number at 1-239-768-7547 for technical assistance. I hope this helps you with your problem.
My Viore flat panel tv comes on for a few moments, then the lamp and temp/standby light flashes and the screen goes dark. The picture is just fine for the first few moments, and then it goes dark. Any
this is caused by a bad connection, or a faulty back light. It is also something you should have a local repair man have do for you if you are not "tech savvy".
RCA M50WH92S PICTURE COMES ON FOR ABOUT TEN
Replace your LAMP if all of your Fans are running! If lamp fan is not running Lamp will not turn on .Call FOX for Lamp 1-800-227-5369
3helpful
When watching tv on any mode...after a few seconds screen goes dark and sound goes out...then a few seconds later it all comes back...happends repeatly...any thoughts?
Time to replace Lamp in TV.
Existing lamp getting weak and causing that problem, replace lamp and TV will be fixed.
Buy Sony original lamp for TV safety and lamp replacement procedure is written in user manual.
Thanks.
Turn on and screen goes blank after 45 seconds
I found the problem was related to the lamp. Your TV power up but then the lamp would overheat and automatically shut down (audio and video) resulting in a dark screen with no sound. Once the lamp cooled (30 - 60 secs) it would come back on. Then overheat, turn off - recycling "eternally". A new lamp will solve the problem
Bye
1helpful
Picture goes out, comes back, sound is fine
I found several instances of this probllen on various forums, and determined that it is the bulb after all. It seemed that a bulb should either work fine or be burnt out, so I thought it might be something else, but so many other customers had this identical problem that I am 99% sure it is the bulb. I found a replacement bulb with housing for about half the price of the Sony Store, so i ordered it. In the meantime, another customer offered a suggestion to try adjusting the Power setting to Power Saving instead of Standard. I tried this last night and the picture worked fine! I will replace the bulb when it arrives and keep the old one on hand in case this happens in the future. Thanks to all of the posters out there!!!
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
1helpful
2answers
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
2answers
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
