SOURCE: IN CANON IR2270 SHOWS ERROR CODE E0049001
there might be something jammed in it like paper so check all the compartments or the ink section if thats not hte case then get it checked out by a professnial
you have the wrong ADF installed on your machine this is the error code E490-001
if this is the code then you have the wrong ADF on the machine ther is no E049-001 code so i figured it was a E490
SOURCE: what does an error message E000007-0000 mean for a
E007 is fixing film trouble error.Its not related to laser in any way.
These means that you need to change the fixing foil or fixing film assy.
Hope that helps!
If you want the service manual write on [email protected]
Error Message e00007 code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
