After running a load or two of laundry, my control panel becomes unresponsive when trying to start another load. It goes "beep beep beep" when I press start or any other button on the panel. Unplugging used to work however does not now. I have read some entries where folks suggested running a diagnostic on the panel. How is that accomplished?
Does it say do in the display as if the door is open??
hold down delicates and heavy soil for 3 secs
machine displays 0
press presoak
will display d
use the wash/rinse temp arrows to scroll through the codes there will be lots some unimportant others more important write them all down
I will continue with this great advise for a solved rating
Ok this makes a lot of sense Code 15 means the computer sees on of the touchpad keys is stuck so you most likely need a new comsole/membrane assembly.
OK! No more advice till i get a solved for this one!lol
Heres the Membrane Pad Check Routine
machine displays 0
press wrinkle free
now all the leds turn off -- maybe one will be on if its shorted
each button can be toggled on/off one may not respond
try this let me know what you find
part #22003238 Will send you one for $174.99
Not covered by factory warranty - the computer only
Hey Salvador Juarez, I appreciate your post!
I understand that when you try and press the dryness cycle on your Frigidaire laundry center it provides you an error. I would like to ask you some additional questions in order to best assist you. Does it show you a code or beep? If so, how many times does it beep? I look forward to your response. Thank you. -Matt
The door is closed and the panel does not show any error codes.
The only number we received was 15. Thanks for your help so far!
Thanks much. Wonder if that is covered under the year 3-5 warranty that covers electronic control.
My fully automatic frount loader beeps and only the temperature lights are on, nothing else is on display, and no effects if I press any buttons or turn the nob, any suggestions?
Thanks in advance.
