Question about Nikon D50 Digital Camera with 18-55mm Lens
D50 with a new 18 -200 Nikon lens
I bought a new nikon 18 - 200 VR lens. I took 6 pictures and the lens is not longer autofocusing.
  • 1 more comment
  • Anonymous Dec 06, 2007
    I have nikon 18-200 autofocus lense and now using with Nikon D200, lense does not auto foucs
  • Anonymous Jan 05, 2008
    I have the same camera...bought new off ebay. It came out of the box not auto-focusing.
  • Anonymous Apr 15, 2009
    Have D40, bought 18-200 VR. After 2 months it is not autofocusing.
    Novelist:
    Champion:
  • 214 Answers
Is the Auto/Manual Focus switch turned to Manual? This can easily be moved without realising that you have done so.
If not, get it checked out under Warranty. If you try to do anything yourself you will void the Warranty.
Good luck.
Posted on Apr 13, 2008
6ya staff
SOURCE:
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
May 22, 2011 | Nikon Cameras
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
Sep 28, 2010 | Nikon Normal AF Nikkor 50mm f/1.4D...
Autofocus stopped working
I fix these all the time for this problem, The focus motor is bad, Tony
May 23, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Autofocus does not work
I fix these all the time for this problem, The focus motor is bad, I charge 145.00 to fix these, Tony
May 11, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Lens has lost ability to autofocus.
Nikon guarantees 5 year warranty to original purchaser. If your camera functions with another AF-S lens, then the problem lies with the 18-200mm lens. The AF motor unit needs replacement. Nikon should be able to repair the lens under warranty.
Make a copy of your receipt and go Nikon website to start repair service.
May 08, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Autofocus no longer working. It will not take a picture in autofocus mode. As soon as you switch to manual, it allows you to again.
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Dec 30, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
My Nikon D80 will not autofocus
Fix your issue with these steps:
1. Try forcing the lens to rotate a fraction of a inch. This will sometimes help the problem. Or simply move the switch from M to A on the lens.
2. Try to switching to a single of the 11 auto focus points. Then try if there are specific points that are the problem.
3. If all auto focus points are fine, try updating the firmware or cleaning the sensors inside the camera behind the mirror. If a one or more points are out of order, also try cleaning the sensors behind the mirror.
4. Detatch the lens from the camera, by applying pressure on the release button and twisting the lens so it can be released. See picture
5. Set the camera selection wheel to manual (M), see picture
6. Turn the camera on, and start the liveView format. This will flip op the mirror inside the camera.
7. Take a dry can blower. Or if in lack, use an empty plastic bottle, without moisture inside, and use it to blow on the autofocus sensors.
They are located at the bottom under the mirror. NOTE Do not blow with your mouth, small amount of moisture will hit the CCD also located here.
8. Turn the camera off
9. Reattach the lens. Push the lens, white point to white point and turn the lens in place.
10. This worked for me, hope it also helped you ;)
For more solutions check Nikon D80 Manual
Apr 03, 2017 | Nikon Cameras
Best Auto focus Tele For Nikon D40
hi ! iam too a D40 holder,u can opt for AF-s versions or HSM sigma,both of them autofocus on d40,can go for 18-200 AFs VR or if u need still longer end go for 70-300 but it is costly than the sigms 70-300APO DG HSM MACRO..,its a much better reviewed lens and dont forget the cost..anyway do some research before considering..good luck
Mar 14, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Nikon D50 Digital Camera with 18-55mm Lens Logo
315 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
