The generator is producing 80 volts and should be producing 110 volts
SOURCE: No voltage output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
SOURCE: generator not charging
look where you plug items in for power there should be a little circuit breaker there (a little black button) puss it in you should be ready to go.
