LG RUMOR Cellular Phone Logo
A
Anonymous Posted on Nov 06, 2013
Can you add a sim card to a ln510 lg rumor touch, sprint
3 Related Answers
Anonymous
  • 113 Answers
  • Posted on May 19, 2009
SOURCE: How to unlock LG Rumor from sprint
The LG Rumor is a Sprint CDMA device. This means that it is activated on a network using the Electronis Serial Number programmed into the device. Once the device is powered up, it registers to the network and if that ESN doesnt match an active acct, then no service, and you may get a message asking you to activate your device. Sim cards are only in GSM devices (not including nextel and a few devices that have been dubbed world phones, allowing them to work on both CDMA and GSM services.)
So, all this was to explain simply that you can never put a sim card in a LG Rumor. There is nowhere for it to go. SRY!!!!!
PLS RATE THIS POST AS FIXYA.
ismael castillo
  • 318 Answers
  • Posted on May 19, 2010
SOURCE: uploading contacts from sim card to lg rumor
You have to make sure your contacts are saved on to your Sim card because if they were stored on the phone's memory they wont appear on your new phone when you switch the sim card over. Once you are on the phonebook you should be able to see a setting that says something like IMPORT contacts to sim card and then when you put it in the new phone you will hit IMPORT contacts to phone.
www.usedcellphoneshop.com
Anonymous
  • 32 Answers
  • Posted on Mar 03, 2011
SOURCE: I need to change the modem or usb port in my lg
Hey there,
You need to also have your SPC code and enter that after you try the code ##port#. Once you do that you can select DM mode.
Here is a link to a website which has a lot of information about this procedure (under tethering sub category)
http://wiki.howardforums.com/index.php/LG_Rumor_Touch
How do i unlock the carrier!
This is a CDMA phone, which mean that it can only be use with Verizon or Sprint, or any other company that does not require the use of a SIM card. This means that you need to take it over to Verizon and tell them that you want it unlock so that it can be use with any other CDMA carrier. It won't work on AT&T or T-Mobile, or any GSM carrier.
Find serial number on sprint LG rumor touch
Just bring keypad up and dial *#06# and it will show your imei/serial number.
Need manual for lg rumor touch phone
The link below will take you to a pdf file of the users manual for the touch. This one is published by Sprint but the carrier makes no difference.
http://shop.sprint.com/global/pdf/user_guides/lg/rumor_touch/rumor_touch_by_lg_ug.pdf
Lg rumor touch cell manual
You can download the Sprint LG Rumor Touch manual in this site http://support.sprint.com/global/pdf/user_guides/lg/rumor_touch/rumor_touch_by_lg_ug.pdf
LG Rumor Touch quick start guide: http://support.sprint.com/global/pdf/user_guides/lg/rumor_touch/rumor_touch_by_lg_gsg.pdf
Mar 30, 2011 • Cell Phones
4helpful
2answers
Will my phone work
Above is incorrect. Boost uses two different networks each is different technology. The one using SIM cards is the IDEN network (Nextel). The other is Sprint (who owns Boost) and that does not take a SIM, it's a CDMA network. All Sprint phones can work on this network,but you must get Boost to activate the phone. They won't do this unless you are already a customer and tell them you are replacing a broken phone, then give the Sprint phone ESN# (under battery) for them to log in your account. If you have a Sprint LG Rumor it will then work without unlocking or flashing, no changes necessary.
3answers
15helpful
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
