Samsung SGH-E251 Mobile Phone - Black Logo
Posted on May 01, 2009
Cant get downloaded ringtones to play as message tone
How do i get a downloaded ringtone to play as my message tone on my sgh-e251 mobile
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
123
Points
AT FIRST GET THE TONES IN PHONE MEMORY.NOW GO TO PHONE PROFILE IN PHONE SETTING.THEN EDIT PROFILE.SLIDE TO NEW MESSAGES.THERE YOU CAN SEE THE OPTIONS
1helpful
Downloading
Your computer is full of potential free ringtones for your Samsung T229 (also known as Samsung SGH-t229, T-mobile t229) :
By Bluetooth:
The Samsung t229 is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Samsung t229.
Simply record sound directly:
Since your Samsung t229 has a sound recorder (also known as "voice memo"), a very simple technique involves simply placing your phone near your computer's speakers, playing whatever music or sound you would like as a ringtone, and recording it -- you can even use your voice, your child's voice or even your cat's "meow!" Record it with your mobile and there you go! Unless that function was specifically blocked on the Samsung t229, you should be able to navigate to the ringtones section and choose your new recording as a ringtone. Of course, the quality will not be ideal but, after all, it's free!
Downloading using the phone
NOTE: MegaTones, HiFi Ringers, and Voices & Sounds are stored at Menu > Fun & Apps > Files > Sounds > Sounds. To download using the phone, perform the following steps: 1. At the main screen, select t-zones. 2. Scroll to and select Music & Sounds. 3. Scroll to and select HiFi Ringers, MegaTones, or Voices & Sounds. 4. Scroll to and select the desired category. 5. Scroll to and select the desired tone. 6. On the preview page, select ACCEPT. 7. After the tone downloads, select Play to preview the tone. 8. Select Set as. 9. Select one of the following options:
  • myFaves ringtone: To set as a myFaves® ringtone. Scroll to and select the desired myFaves contact.
  • Default ringtone: To set as the default ringtone.
  • Caller ringtone: To set as a caller ringtone. Scroll to and select the desired contact.
  • Alarm tone: To set as an alarm tone. Scroll to and select the desired alarm. Turn on the alarm and select the desired time and date.
10. Select Save.
6helpful
2answers
Change message alert tone samsung l700
can i change my message tone to alert tone
Message ringtone on my phone isnt loud enough.
you have to change your tone or loud tone and must reset the volume of your message tone
6helpful
2answers
L700 model - want to change message tone which I
Hi buddy!! Samsung sgh-l700 also supports other message tones. But to utilize it you must convert the required tone into MIDI format. You can do this with this software- "MP3 to Ringtone Gold".
1helpful
How to change the message ringtone of my phone
Hi Jane,
To put mp3 files as message tone you have to download a .mid file and put it in with all of your other mp3 files. once you have done that go into settings and go to the message tone settings. press use my effective alert tone or what ever it says and click play on the .mid file the just go across and find the mp3 you want but dont go out of the play mode until you select the mp3 you want.
im glad i could help.
5helpful
There are supposed to be 64 ringtones on my sgh
if you had downloaded them then they could be in the music or sounds folder of 'my files'.
if not, the sgh G600 actually comes with much less ringtones
[providers of the phone often provide conflicting information as to the phone's spec.]
there are a few if you go into:
Menu;
Settings;
Phone Settings;
Phone Profiles;
'Normal';
Then on 'Incoming Calls' scroll down to 'Voice Call ringtone' and select it.
In this section there are 10 ringtones.
If you want to change message tones:
Phone Profiles;
Normal;
scroll to the right so you are in the 'New Messages' tab.
To change the alert tone, scroll down to 'Message alert tone' and select. Here there are only a few message tones.
hopefully that solved the issue.
3helpful
2answers
I would like to change text message ring tone but can only find how to change ringtone and not for text messages
I found the answer!! Go to Menu>Settings>Profiles, then go to Options>Edit. Push the right side of the square (that you use to navigate the menus) so that you're working with New Messages, not Incoming Call. Go down to Message Alert Tone, then go to Options>Change>Use Effect Tone. If you were trying to use an .mmf that you downloaded, or any of the preloaded ones that can be used as incoming call ringtones, you'd go to Use My Alert Tone here. There are 4 tones under Use Effect Tone, and you can play them and choose one, just like you do to play and choose your ringtone.
5answers
Set a ringtone for a text message SYNC SGH-A707
"My Effect Tones" can only be MMF files. Ringtones can be WAV, MMF, MP3, etc... as long as the file is under 300kb I think. You need to convert your ring tones to MMF to use them as "Text Tones"
1helpful
3answers
Setting ringtones as message tones for Samsung Sync
it's because the sync can only use mp3s for an actuall ringtone..for anything else it's .mmfs. i know what you're thinkin...riiipofffff.
3answers
How to download ring tone
http://www.mtv.com/music/artist/usher/ringtones.jhtml --> see if it helps.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
