The location of the reset button on a Veon remote control may vary depending on the specific model, but in general, the reset button is usually located on the back of the remote control. Look for a small, circular button that may be labeled "Reset" or "RST".
To reset the Veon remote control, press and hold the reset button for a few seconds until the LED light on the remote control turns off and then turns back on again. Release the reset button, and the remote control should be reset to its default settings.
If you're unable to locate the reset button on your Veon remote control, consult the user manual or contact the manufacturer for assistance.
look for a model number on the remote and google instruction manual or call if they have a help line audiosonic is your option or ebay the veon model number and to order the original is best bet. universals are iffy
Hi if U r using 3 RCA cables RED WHITE ,& YELLOW connect them to the input sockets on TV red is audio & white is audio yellow is picture then set the TV to AV .. INPUT.cheers
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
