My tablet wasn't running too bad, but now its getting slower and slower and is starting to freeze up. What can I do to fix this problem?? Any suggestions?
This tablet is absolutely junk.
Just throw it in the trash can.(don't forget to reset it to wipe everything off) And please don't give it to anyone, you might be sued....Haha.... Paul H
hi Debbie. The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet
How do I make my tablet run faster?Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authorityhttps://www.androidauthority.com/11-tricks-make-android-run-faster-414542/Search for: How do I make my tablet run faster?
or go to this link should help you out some more. tablet running really slow Google Search
The Daily TelegraphJan 17, 2015 - Since then the tablet has been very slow. It often freezes and sometimes will not access some websites. Is there going to be another update or ...
Android CentralOct 2, 2014 - Make your Android fast again - it *is* possible We've all been there. ...but the biggest reason I choose my S3 over S5 is memory! no 32GB or more option!..... Those apps are NOT running anyway after boot up (they're not set to ..... Some games may animate so fast you'll have to slow them down a little.
Hi Lesy, let the tablet run out of power or more to the point make it run out of battery then wait 6 hours then fully charge it before turning on. Cheers Greg.
Apps. Select Google.
Clear cache.
If that doesn't work select uninstall updates. You will be questioned if you want to reinstall factory version. Select yes.
If that doesn't work back up and reset tablet.
Check for the reset pin hole on your tablet. Get a paper clip and push it 'gently' in the hole and hold it for thirty seconds. This resets the tablet.
Youdon't want to push hard as there is just a tiny button in there that can get dislodged.
