Nikon COOLPIX L18 Digital Camera Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error" message.'' PLEASE HELP! I don't want to replace this camera so soon.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on May 01, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2956438
Points
33084
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
All of a sudden, my MacBook says "cannot recognize format" of some of my Nikon Coolpix L18 pix and won't download my last 10 pix, nor any more that I take. It downloaded the previous 20 pix...
Sounds like the memory card in the camera has gone bad, or the camera has glitched. Try replacing the card. If it still does it, the cam has issues.
1helpful
Lens error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
From the manual: "Turn the camera off and then on again. If the error persists, contact retailer or Nikon-authorized service representative."
1helpful
Nikon CoolPix L18 getting lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Lens error
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon-authorized service representative."
My Nikon Coolpix E7600 has a error message of Lens Error when you turn on the camera.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
