Hardware Alarm shows up on the screen after replacing the ribbon and we can't print to it.
SOURCE: please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
SOURCE: Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
SOURCE: Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
SOURCE: Tally T2250 showing an error..
If you are using re-fill ribbon then the problem may arise , if you are using original then clean the encoder strip with isopropile if not solved change the encoder strip .
SOURCE: tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
