Question about Tablets & eReaders
My goclever tab r76.2 will not charge or turn on what do i do ?
    New Friend:
Hi my sons tab keeps turning it self of when playing games????
Posted on Dec 26, 2013
6ya staff
SOURCE:
Letter 'B' doesn't work on my keyboard!!!!!
You could try re-calibration, or reset the device, or restore device factory settings as per the below 3 options. There is also a link at the bottom to a user guide. If that doesn't work, you probably have a faulty touch screen, in that case return the device to the place of purchase for warranty repair/replacement:
Q: G-SENSOR is not responding.
A: You should calibrate your device using 'Settings' / 'Display' or Gravity Calibration App (optional).
Q: My GOCLEVER tablet does not react well, it is freezing, works much slower than normal or does not respond at all.
A: We recommend to restart your device using turn on/off button (pressing 3-4 sec) or reset button (with a pointed object).
Q: How do I restore factory settings?
A: You should use 'Factory reset' function available in the 'Settings' App. The factory reset will help if your application causes the inappropriate operation of your device. Note, that all your files will be lost, so we suggest to copy them to another device (pendrive, PC etc).
http://1palladium.com.ua/load.php?f=goclever-terra-101.pdf
Oct 13, 2014 | Tablets & eReaders
Why My GoClever Tab Terra 70 L won't turn on?
Sounds like you've damaged it beyond repair. Get a new one.
Jun 21, 2014 | Barnes & Noble Nook Tablet
How can I get my Maxwest Tab-9100 to charge?
This can happen when a faulty charger isn't providing enough voltage/current. Faulty chargers can provide enough power to trigger the 'Charging' indicator and maybe even to power the unit but not enough to energise the units charger circuit. Try another charger (same voltage) or charging it through the USB socket.
Jun 05, 2013 | Other Maxwest Telecom TAB-9100 Wi-Fi...
How to reset my go clever tab r70
Had a similar problem with GoClever Tab R70 ; was also getting 'Ui Launcher has failed' Error ... Solved it by 1. Charging Tablet with USB power cable. 2. Using Bent Staple / PaperClip to press in reset Button at back. 3. Switch ON by Pressing and Holding BOTH Power On Button and Volume Up buttons together. This Boots up to a recovery Screen with a picture of Green Droid Laying Down with an Exclamation Mark inside a Red Triangle. 4. When you see this screen release buttons and again Press Power Button and Volume Up together to bring available options onscreen. Navigate Options with Volume Up and Down and Select by pressing Power Button. 5. If this doesn't work use paperclip /staple to reset and start again. 6. If there's nothing precious on your Tablet i'd recommend factory reset and to be doubly safe remove any microSD card that might have any data you want to keep. Thanks to this Youtuber for helping solve my Tab Problem : www.youtube.com/watch?v=jLgmptgKeNU
Mar 29, 2013 | Tablets & eReaders
GOCLEVER TAB R70 INSTRUCTION MANUAL
GO Clever Tab R70 turned off and will not turn back on any help tried to reset it but does not help anyone else had this problem and how did they sort it???
Mar 28, 2013 | Tablets & eReaders
Google play update for goclever andriod r74 tablet
hi did you solve this ? if so how plaese
Aug 23, 2012 | Tablets & eReaders
I have been trying to turn on my galaxy tab but it just wont turn on. I have tried charging it for a full day but still nothing. i dont even know if it is charging.
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
Apr 30, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
400 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
