Question about Microsoft Surface RT
The surface logo stays frozen on my surface rt
Regardless of switching on or off the rt does not respond''still **** on logo
What do I do to my next book Ares 8 ? Every app I open says not responding?
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet. how do you rest nextbook tablet
Jan 07, 2018 | Tablets & eReaders
I watched Netfdlix yesterday on my ipad but today it just sits there trying to download, what is going on
Hi Shirley,
Chances are it's suck trying to update. What you could try is to:
  1. Hold the Lock Button until the Shutdown screen appears.
  2. Shutdown your iPad.
  3. Hold the Lock button again until the Apple logo appears.
  4. Let it startup and check to see if Netflix is updating
I hope this helps,
Niall
Oct 07, 2015 | Apple iPad Air
My IPad is stuck with the apple logo on a black screen while resetting to factory settings. No more movement now. What to do?
Don't forget to plug in the power. And again, press home button and on / off switch, till it switches off. Then press the on / off button, till the Apple logo comes back, then release the button. It can take up to a minute, before the screen comes on.
Sep 27, 2014 | Apple iPad (16 GB) WiFi Tablet PC
What do I do when my surface tabnlet will not turn on.
Sounds as though the power has gone. Try plugging in the power then start it up..
Aug 02, 2014 | Microsoft Surface RT
Microsoft surface tirns on and logo appears but wont do amything else
To reset your Surface without logging in, please try the following:
1. Attach your Touch Cover / Type Cover
2. Power on your Surface
3. Press and hold the Left Shift key at the Login screen
4. Press the Power icon
5. Press Restart
Your surface should boot to a light blue screen with some options on it.
1. Click on Troubleshoot
2. Click on Reset your PC
3. Follow the prompts. Let me know if this does not work for you.
Mar 14, 2014 | Microsoft Surface RT
Surface rt is slow and freezes
Sounds like you need to do a system refresh, RT is usually quite responsive.
Swipe right to open charms menu, then click on Update and Recovery, then Recovery, then choose "Refresh you PC without affecting your files".
Good luck.
Feb 23, 2014 | Microsoft Surface RT
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Hi guys, during upgrade I did something wrong. So, now I have on screen of my tab logos of pc and mobile with triangle in between. No charging, non responding, no hard reset available. Please, help...
Have you tried the hard reset? Try these instructions for a hard reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
Mar 02, 2011 | Samsung Galaxy Tab Tablet PC
Microsoft Surface RT Logo
Top Microsoft Tablets & eReaders Experts
Ekse
Harrie
Ruben Caraballo
Ruben Caraballo
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
