Keypad was working well then stopped working when replacing volume up button. the power button on/off is still working but all other buttons not working.
SOURCE: Keypad buttons not working
some time if your cell has felt then it can also that print hve open of your keypad .so please check your signal first and then if it is opened ,check your keypad ic.
SOURCE: nokia 3110 power button doesn't work, can i open by using any other button.
u must get a new power switch from Nokia Care
SOURCE: how do i lock my keypad on my nokia 5130?
hello,you can kindlyb follow the shortcut procedure below,
press MENU>AND STAR BOTTON ON YOUR KEYPAD.BUT YOU HAVE TO MAKE SURE IMMEDIATELY YOU PRESS THE MENU BOTTON YOU CLICK ON THE X BOTTON ON THE BOTTOM LEFT OF YOUR MOBILE PHONE IN NOT LESS THAN 2 SECONDS.
THANKS FOR USING FIXYA.
TAKE CARE.
Testimonial: "Thankyou so much."
SOURCE: my nokia 5130 express music
This is a software problem.Just take the mobile to nokia care and they will reinstall the software and problem will be solved.
Thank You
