Both charger ports on my android tablet will not take a charge. The chrager I got with the tablet stopped working first then I started using my phone charger which worked great for months. I then had to wriggle it about to get it to charge until it stopped.. I can get my tablet to go on I can now plug both chargers in get them to go on for a very short time then nothing. Please help I miss my wee pink tablet!!!
SOURCE: the place where i enter my charger has broken inside the tablet
That you would need to go either to where you purchased it to be repaired, or they will have to send it out to the manufacturer to be repaired. That is not something you can fix yourself. At least, I would not recommend you trying.
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at mpcdrivers.com
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
was using the tablet sat it down came back to it it was off and wont come back on even if i plug in to charger......
