Sony DVP-SR660P DVD Player Logo
A
Anonymous Posted on Nov 09, 2013
Sony DVPSR660P DVD PLAYER How to SET REMOTE VOLUME
ANSWER
M.udhaya sankar
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 31, 2017
M.udhaya sankar
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
410
Points
Sony remote DVP-SR660P volume key not working how to work
Sony DVPSR660P DVD PLAYER How to SET REMOTE VOLUME - 5_31_2017_6_36_11_am.jpg
5 Related Answers
Anonymous
  • Posted on Mar 11, 2009
SOURCE: remote control for dvd won't work
the + on my Sony DVD in not functioning only the - is working please help
Anonymous
  • Posted on Dec 04, 2009
SOURCE: sony dvd players codes on rca universal remote
unemployed and cant affoed to go to your site sorry will figure out another way.
Anonymous
  • 312 Answers
  • Posted on Jun 17, 2010
SOURCE: I have a 36
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
Anonymous
  • 9 Answers
  • Posted on Jul 22, 2010
SOURCE: Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Anonymous
  • 14553 Answers
  • Posted on Jun 14, 2012
SOURCE: Att Uverse remote set up code for Sony Dvd player
Google for it by model numbers but I doubt you will find one that works.
Not working volume control in sony dvd dvpsr660p by remote
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
https://youtu.be/wUpnETSm6_k
Need to no how to make my Sony DVD player remote work the volume and power on my Philips TV
Does the remote have a TV setting? In other words, is there a setting on the remote where you can go back and forth between TV, DVD, Cable, etc? If not, you cannot use it for that purpose. If it does, try setting up your remote with one of the following codes.
11454, 11054, 10690.
How to set up remote control so it will work volume and power on my philips tv the sony player i have is a dvp.sr200p
Why not use the Phillips remote to control the DVD instead of the reverse?
The Sony codes are listed below.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
HELP! Dog stepped on remote and now volume on Sony KP53S65 won't work.
test this steps and fix it. God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
2answers
Sony DVD Player not working
The controller board is slowly dying. I think it might be time to buy a new DVD player.
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Code for sony tv are 0000, 1100, 0810
Thank You
I have a 36" insignia tv and just bought a sony dvd player and in the user manual for the dvd player there is no code for the remote for an insignia tv which i find wierd seeing as insignia is made by sony...
Want to make sony dvd remote work on sony wega tv
Sony dvd player remote will only turn off and on tv volume and input.
Sound output reduced
There is a volume control on the Remote of your DVD player , increase the volume in that and it should solve. Additionally check the audio output cord of DVD player if it is intact and tightly fitted.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
