Question about Hammering
Was useing kango breaking concrete and it stopped working
  • 1,631 Answers
Check:
  • frayed wires where it enters Kango
  • is power at switch
  • Power thru the switch
  • Frayed wires at cord plug
  • And finally - Brushes
These are the EASY checks, if none of the above, take it to your local service center.
Good Luck
Posted on Mar 31, 2015
6ya staff
SOURCE:
How to fix a kango jackhammer 950x stopped working a little smoke came out, replaced brushes and still not working for one had come off the wire switched on still did not work?
http://project21designs.com/download/kango%20900%20&%20950%20manual.pdf
Electric Switch measure it the suppression capacitor A collector from the armature was come out and ruined the brushholder(s) only a cable break the electric field a problem.
May 01, 2014 | Hammering
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
May 19, 2012 | Milwaukee Tool Hammering
I cant find kango oil for my kango electric hammer
What kango hammer do you have? I am most familiar with the UK kango 900 and 950, pre-milwaukee.
Sep 18, 2010 | Hammering
Schematic diagram of kango breaker 900x
The 900 is a hammer only, the 950 is a hammer drill. the newer ones 950s used spline bits. Unfortunately new parts are no longer available for these great machines. What is your problem.
May 20, 2010 | Hobby Drill
What type of oil should I use in a Kango electric hammer type m(di) ? Is it possible to get a parts/service manual for this (I realise it is old. Thanking you in naticipation of a reply-Charlie
\charlie use sewing machine oil, as for a book on it put the make model into google and a pdf might be available as for parts not really unless you sroce them through the paper or ebay
Apr 24, 2010 | Hammering
Kango 900 demo hammer on off switch needs replacement were can i purchase parts.
what country are you in? in australia atlas copco are the distrbutors. i`m sure you can find out on the internet
Aug 11, 2009 | Hammering
My jackhammer seems weaker than what it should be. it runs and functions, but doesn't sound as loud as it should, nor have the power it should.
if pneumatic, it needs to be oiled with some air tool oil into the air supply nipple, 4 drops a day when used
Aug 08, 2009 | Hammering
Kango 950k
it sounds like it needs service,service is taking lower unit apart cleaning and regrease with special kango grease, if unit was serviced recently or not used much, grease could be real old and dry,sometimes you have to warm up unit before they start hitting correctly,,also if used a lot could be dirt build up,inside bit holder.remove bit holder clean out dirt regrease with heavy bearing grease,just grease the lower part,not very much grease is needed
Jul 28, 2009 | Electric Demolition Jackhammer
LOOKING FOR A MANUAL & INFO
Milwaukee now owns Kango, unfortunately I believe the 950sv is the old style. Parts are no longer avail. I have about 20 of the breakers. It is really too bad, they were great machines.
Jan 15, 2009 | Electric Demolition Jackhammer
Hammering Logo
1,019 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Hammering Expert? Answer questions, earn points and help others
