Question about Brother Disney ULT-2002D
Bottom thread does not grasp upper thread. needle changed inside cleaned still does not work. How do I get to the timing device to fix it. sewing machine center stated " I'll have to order some parts how do they know that before even looking at it.
It is amazing how much those stores know. I suppose that could be a common thing among that particular machine.
Whatever you do don\'t buy a "WHITE" machine as they work for about 2 hours then they die. I had to keep taking it back and forth 45 miles each way for over 1 month and the person whom owned a shop couldn\'t fix it. Of course he said it was fixed and when I stepped on the gas nope same thing happened.
I also won\'t ever buy any new singer machines. They are bad...now if you can get a hold of an older one that is medal inside instead of plastic parts it would pay to keep it running.
I have sewn for over 42 yrs. I have gone threw a lot of different machines trying them out. I own about 6 machines now not including my embroidery/sewing machine or serger. I always have one or more working. I was tired of having it break down at Christmas time.
I even loaned out one to my 18 yr. I took her 20 yr old Janome (all metal inside) machine into the shop.
Oh yes, youtube has videos on everything!
Posted on Nov 10, 2013
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: my needle won't pick up the bobbin thread
My sewing machine is a Brother LS1217, well actually it is my son's, and he uses it very seldom. I went over to put in a new needle and I cleaned it top and bottom, put in a new bobbin, and a new needle and the needle won't pick up the bottom thread. What am I doing wrong? Please help me!! It has to be something simple, as this is such a simple machine! roseandjimmy@yahoo.com
Posted on Oct 23, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong. I have this machine, and I know that it is really easy to put the bobbin case in wrong. Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth. My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works. Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right. In other words, it has always been my fault.
Posted on May 25, 2009
SOURCE: Brother CS-6000i - the bobbin thread is not coming
Check list:
1 - Flat side of the needle is facing the back of the machine.
2 - Threaded machine with the presser foot up - always.
3 - Bobbin thread is feeding from the spool in the correct direction and through the proper guides.
Lower and raise the threaded needle, holding onto the end of the thread.
If this does not pull the bobbin thread up, the timing may need adjusting.
There is a graphic for doing this as sewusa.com or take it into the dealer for service.
Posted on Mar 10, 2010
Oct 10, 2016 | Singer Sewing Machines
Aug 27, 2008 | Consew Sewing Machines
Sep 13, 2016 | Singer 4411 Heavy Duty Sewing Machine
Feb 22, 2016 | Sewing Machines
Sep 24, 2015 | Sewing Machines
Aug 04, 2012 | Bernina BERNETTE 65 Mechanical Sewing...
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Nov 28, 2009 | Brother CS-8072 Computerized Sewing...
Jun 01, 2008 | Bernina Virtuosa 150
Nov 12, 2007 | Kenmore 12102
61 people viewed this question
