How does one set the clock on this system?
Select Clock Adjustment mode Press the [FM] or [AM] button. Select the "Clock Adjust"/ "CLK ADJ" display. 2 Enter Clock Adjust mode Press the [4] or [¢] button for at least 1 second. The clock display blinks. 3 Adjust the hours Press the [FM] or [AM] button. Adjust the minutes Press the [4] or [¢] button. 4 Exit Clock adjustment mode Press the [MENU] button.
replace the [4] with >
SOURCE: Hi there, I have purchased a vehicle with a
hold in the menu button till the functions appear on the screen then turn, press control buttons till you get the settings that you want
SOURCE: Unable to set clock on car radio
On the Radio there should alpha neumeric print on the front of the head unit on one of the corners. It should be something like CDX-RA700 or something to that extent. If you could get me that informaiton I can help you a little more in detail and what it means as RDS
SOURCE: adjust clock
press and hold menu button for two or three seconds to enter menu, then use am and fm buttons to scroll up and down. when you get to set clock press seek up for two or three seconds and then use am fm seek up and down to adjust time.
