Breadman TR2200C Ultimate Bread Maker Logo
Posted on Nov 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paddle axle fell out the bottom on the pan while washing.
I have a Breadman Ultimate Plus Tr2500bc. The piece that couples to the motor that slide up into the the middle of the pan, from below the pan, that the paddle attaches to came  loose and fell off while washing. Sorry Breadman doesn't show or post a break out schematic of this nor can I find a part list for it, just the paddle that attaches to it, so I do not know what to call it, maybe the paddle axle? The inside of the pan has the red washer still. Is this all the parts? What holds this thing in place? It fell out the bottom so the top part of the shaft is what is missing something. It looks like the shaft, when you insert it from the bottom, near the red washer has a circle cut in it, does one of those E-clips slide into this? So to replace this I would just slide the pieces in from the bottom and E-clip it above the washer or below? Do you just pry out the washer? Is the washer a common size? I might want to replace it. Does it require any kind of grease on the bottom before sliding the shaft in? Amazing they do not give simple replace/repair  instructions.
John
Level 2:
Scholar:
  • Expert 140 Answers
  • Posted on Nov 10, 2013
 John
Expert
Level 2:
Scholar:
Answers
140
Questions
Helped
28371
Points
285
I looked through the manual for this unit and you need a more comprehensive parts drawing showing the drive details. They do not have this kind of detail on line, my advice is to contact them directly by phone.
http://cart.russellhobbs.com/consumer-services/warranty.aspx?sid=BreadmanUS
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Aug 07, 2008
SOURCE: circular clip holding paddle axle in place
I fixed this by using an "e-clip". You can get e-clips at any autoparts store, or online in assortment kits for cheap money. You have to remove the spring seal and washers inside the pan, you also have to remove the circlip on the bottom of the paddle shaft, you have to install the paddle from the inside once you have the right size e-clip installed.
It's a lot harder to explain than to do, once you get it apart you'll see how things go together. I have no clue what originally used to hold the shaft in, mine made sqealing noise, when I took it apart there was little left of the original part.
Piece that connects to motor and then paddle fell out
Yes, the C-clip holds the shaft for the paddle in place. I think the only relevant replacement part is the entire pan. Expensive!
Dave Kristol
I need a paddle for my breadman ultimate plus (tr2500bc). Any suggestions?
Put this item number (390094347444) into an ebay search and it will pull them up for you. Looks like they are New and have many available. Suggest buying more than one to have a back up on hand.
2answers
Need a replacement pan for a Breadman Ultimate Plus, Model TR2500BC
Did you ever find a replacement pan? If not, I have a brand-new one.
1helpful
2answers
Breadman tr2500bc pan popping out
I read in a review that the pan can warp if you read instructions because it said to fist run the machine in quick bread mode to clear factory coating. Review said to run in quick bread mode with lid open so it doesn't overheat, heat warps the pan, so it pops out . However manuel never mentions to leave lid open. I just got one and hope they are right. I just ran it new no ingredients quick bread lid open...
Breadman Ultimate Plus TR2500BC
i need the bread pan from breadman ultimate model tr2500bc
Top Breadman Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
